The Fujitsu Tablet LIFEBOOK T935 is a versatile 2 in 1 Ultrabook for demanding professionals with dynamic work styles. Its ultra-thin, durable aluminum housing with magnesium lid, just 17.1 mm height, and its super lightweight enable you to travel in comfort. With a simple flip of the super crisp, rotatable WQHD IGZO display with pen and touch support you can switch to tablet mode. The backlit keyboard, enterprise-grade security features, pull-out LAN connector and embedded 4G/LTE let you work securely wherever you are. With the optional port replicator maximum convenience in the office is ensured.
- Fujitsu LIFEBOOK T935 - 13.3" - Intel Core i5 - 5200U - 8 GB RAM - 256 GB SSD - 4G LTE
- Product Type
- Ultrabook - convertible
- Operating System
- Win 8.1 Pro 64-bit
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption
- Display
- 13.3" LED backlight touchscreen 1980 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5500
- Input Device
- Digitizer, Tablet Pen
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 4-cell - up to 9.3 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 32.1 cm x 23.5 cm x 1.93 cm
- 1.6 kg
- Limited warranty - 2 years - pick-up and return - availability: 9 hours a day / Monday-Friday
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s - TCG Opal Encryption
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1980 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Glare, WideView, magnesium lid, tempered glass, IGZO technology
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1920 x 1080
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC283
Input
- Keyboard, digitizer, touchpad, Tablet Pen
- Multi-gesture touch pad, Dual Digitizer
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Generation
- 4G
- Technology
- LTE
- Controller
- Sierra Wireless AirPrime EM7305
- Max Transfer Rate
- 100 Mbps
- Technology
- 4-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 9.3 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- 2 x USB 3.0 , HDMI , LAN , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Adobe Reader, Fujitsu Security Application Panel, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, McAfee Internet Security Suite (60 days trial), Power Saving Utility, Plugfree Network, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, Workplace Protect, Microsoft Push Button Recovery, Windows 8.1 Pro 64-bit recovery DVD, Fujitsu DeskUpdate, Absolute Computrace Mobile
- Case Material
- Aluminum
- Integrated Options
- Dockable
- Security
- Administrator password, system password, hard drive password, Smart Card security, wake on LAN, Intel Active Management Technology (iAMT), Accelerometer, magnetometer, gyroscope, 1 USB 3.0 with Anytime USB Charge
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- GOST, EN 60950, RoHS, WEEE
- 1.6 kg
- 5 °C
- 35 °C
- 20 - 85% (non-condensing)
