The KB900 is a very flat keyboard with extra low keys - with spill-resistant protection. The elegant design and top-quality processing makes the KB900 the ideal input device for any PC or notebook user. Should a small accident occur (glass of water or the cup of coffee) this special construction helps the liquid to flow away. You can continue working and there is no damage.
- Fujitsu KB900 - keyboard - English - black
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- English
- Keys Qty
- 105
- Palm rest, spillproof, red LEDs
- Black
- 46.5 cm x 17.9 cm x 2 cm
- 0.85 kg
- Microsoft Certification
- Compatible with Windows 7
- Designed For
- Celsius J550, J580, M770, R970, W570, W580; CELSIUS Mobile H970; ESPRIMO D538, D538/E94, D556, D738, D738/E94, D757, D958, D958/E94, K557/24, K558/24, P556, P557, P558/E94, P757, P757/E94, P758, P758/E94, P957, P957/E94, P958, P958/E94, PH556, Q556, Q558, Q957, Q958; FUTRO S540, S740, S930, S940
- Keyboard
- Interface
- USB
Input Device
- Keys Qty
- 105
- English
- 46.5 cm
- 17.9 cm
- 2 cm
- 0.85 kg
- Black
- Cables Included
- 1 x USB cable - 1.8 m
- FCC Class B certified
- OS Required
- Microsoft Windows Vista / XP / 7
- 0 °C
- 40 °C
- Designed For
- Fujitsu M2010 , Fujitsu Celsius J550/2, J580, M770, M770power, M770x, R940 POWER, R970, R970power, W380, W550, W550 POWER, W570power, W580, W580power, W580power+ , Fujitsu CELSIUS Mobile H970 , Fujitsu ESPRIMO C910-L, D538/E85+, D538/E94+, D556/2/E85+, D556/2/E90+, D556/E85+, D556/PX, D738/E85+, D738/E94+, D756/E85+, D756/E90+, D756/E94+, D757/E85+, D757/E90+, D757/E94+, D956/E85+, D956/E90+, D956/E94+, D956/LL, D957/E85+, D957/E90+, D957/E94+, D958/E85+, D958/E94+, E400 E85+, E7935, E7936, E9900, K557/24, K558/24, P556 E85+, P556 E90+, P556/2/E85+, P556/2/E90+, P557/E85+, P557/E90+, P557/power, P558/E94+, P710 E90+, P756 E85+, P756 E90+, P756 E94+, P757/E85+, P757/E90+, P757/E94+, P758/E85+, P758/E94+, P7935, P7936, P910 E90+, P956 E85+, P956 E90+, P956/LL, P957/E85+, P957/E90+, P957/E94+, P957/power, P958/E85+, P958/E94+, P958/power, P9900, PH556, Q1500, Q1510, Q520/K, Q556, Q556/2, Q558, Q900, Q9000, Q956, Q956/MRE, Q957, Q957/MRE, Q958 , Fujitsu FUTRO S540, S740, S930, S940 , Fujitsu LIFEBOOK E780, E8410, P3110, P770, S710, S760, T4310, T4410, T730, T900, TH700 , Fujitsu PRIMERGY MX130 S2
