Flexible - durable - high volume scanning; With scanning speeds of 100 ppm/200 ipm (200/300 dpi), the fi-7700 greatly improves process efficiency. Large volumes of information can be captured from various media, including thin paper, plastic cards, envelopes and long page documents.
Smooth paper flow; The fi-7700 automatically adjusts to paper weights from 20-413 g/m². The straight paper path reduces the load on a document and assures reliable scanning regardless of the condition and type of a document. By simply sliding a lever to non-separation mode, you can easily scan thick and long documents folded in half, multi-layered document sets and envelopes.
Innovative paper feeding mechanisms; Skew Reducer automatically handles sheets of paper in a stack individually, so that if one sheet is fed-in skewed, subsequent sheets are not forced into physical skew. This ensures that all information in the documents is captured correctly, even in batches with mixed document formats. The Paper Protection function monitors document movement and automatically stops feeding when any irregularities are detected.
Form follows function; The fi-7700's ADF unit slides to either side or rotates by 180 degrees. The LCD on the operation panel reveals the scanner status at a glance and enables instant operation.
Lower workload before and after scanning; The Automatic Document Feeder's (ADF) independent side guides move to exactly the position required for each batch. The adjustable stacker side guides support neat alignment of processed documents. The fi-7700 flatbed consecutively scans thick, fragile or bound documents even with the document cover open.
PaperStream IP and PaperStream Capture; The fi-7700 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture enhances the document capture process from adjusting scanning settings to performing batch scanning, verifying data and releasing to directories, repositories or subsequent process routines. Users can complete data capture tasks easily with the extremely user-friendly graphical user interface (GUI). Moving scanned batches into a queue for later retrieval is possible as well.
Scan various types of business documents with a single scanner
The straight paper path structure that reduces the load on a document that is being fed, assures stable scanning regardless of the condition and type of a document. By simply changing the feed mode to non separation mode, you can easily scan thick documents such as drawings folded in half, multi-layered receipts, and envelopes with the same straight paper path operation. -
Protect important information by preventing missing edges and document damage
Skew reducer helps improve the feeding performance significantly and prevents a scanned image from missing an edge. Paper protection minimizes the risk of document damage and protects your important documents by detecting abnormalities in sound and document length. -
Design that meets the user's needs
The fi-7700 helps improve the efficiency of operations by providing a variety of functions that make scanning easier for the user. -
Reduce the workload before and after scanning
When setting documents, you can easily align the edges of the documents with independent side guides even if the size of each document varies. For collecting documents, stacker side guide reduces the time and effort that are required for aligning and putting away documents after a scan to prevent ejected documentsfrom being unevenly stacked or aligned.
- Ricoh fi-7700 - document scanner - desktop - USB 3.1 Gen 1
- Document scanner - desktop
- Interface Type
- USB 3.1 Gen 1
- Scanning Sensor Type
- Triple CCD
- Light Source
- White LED array
- Max Supported Document Size
- ARCH B (304.8 x 457.2 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 100 ppm (mono) / 100 ppm (colour)
- Max Document Size
- 304.8 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, bulk objects (such as books, magazines and other bound materials), plastic card, envelope, embossed card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 300 sheets
- Duty Cycle
- 30000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
- 70.6 cm x 50 cm x 34.5 cm
- 35 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 3.1 Gen 1
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Triple CCD
- Bulb / Light Source Type
- White LED array
- Max Document Scan Speed B/W
- 100 ppm
- Max Document Scan Speed Colour
- 100 ppm
- Duty Cycle
- Scanner Speed Details
- 100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 0.6 sec/scan - landscape flatbed - A4 - 200 dpi , 0.6 sec/scan - landscape flatbed - A4 - 300 dpi , 80 ppm - portrait - A4 - 200 dpi , 80 ppm - portrait - A4 - 300 dpi , 160 ipm - duplex - portrait - A4 - 200 dpi , 160 ipm - duplex - portrait - A4 - 300 dpi , 0.9 sec/scan - portrait flatbed - A4 - 200 dpi , 0.9 sec/scan - portrait flatbed - A4 - 300 dpi
- Scanner Features
- Paper Protection Function, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, Barcode Detection, Ultrasonic multifeed sensor, automatic colour detection, Dither, Advanced DTC, Multi-Image Output, built-in LCD screen, RGB Color Dropout, Punch Hole Removal, Deskew, Blank Page Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- Supported Document Size Details
- ADF - up to 304.8 x 431.8 mm , Flatbed - up to ARCH B (304.8 x 457.2 mm) , Long document - up to 304.8 x 5588 mm
- Automatic
- 300 sheets
- Interfaces Details
- USB 3.1 Gen 1 - Type B
- Included Accessories
- ADF paper chute, stacker
- Cables Included
- 1 x USB cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 64 Watt
- Power Consumption Stand by
- 0.35 Watt
- Power Consumption Sleep
- 1.7 Watt
- Software Included
- ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, 2D Barcode for PaperStream, Error Recovery Guide
- OS Required
- System Requirements Details
- Core i5 - 2.5 GHz - RAM 4 GB
- 70.6 cm
- 50 cm
- 34.5 cm
- 35 kg
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Fujitsu Black Document Pad | In Stock | £51.00 |
Fujitsu Extends Warranty From 1 Year to 3 Year For Low Volume Production Scanners - NBD Onsite | In Stock | £871.31 |
Fujitsu Extends Warranty to 3 Year with 8+8hrs On-Site Fix for Low Volume Scanners - Onsite 8 Hours | In Stock | £1,108.54 |
Fujitsu Extends Warranty 3 Years with Low Volume Production Scanners - 8+8hrs On-Site 1 x PM | In Stock | £2,217.09 |
Fujitsu Extends Warranty 3 Years Low Volume Production Scanners 8+8hrs On-Site 2 x PM | In Stock | £3,403.21 |
Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8hrs On-Site + 8hrs Fix 3 x PM | In Stock | £4,770.90 |
Fujitsu F1 Scanner Cleaning Kit | In Stock | £40.08 |
