Fujitsu fi-7700 A4 Document Scanner
Quicklinx: CW1NWS00 Mfr#: PA03740-B001
Type: Document scanner
Form Factor: Desktop
Max Paper Size: ARCH B (304.8 x 457.2 mm)
Interface: USB 3.1 Gen 1
Compatibility: PC
  • Windows 8.1 (32/64 bits)
£5,574.89 ex VAT
£6,689.86 inc VAT
Flexible - durable - high volume scanning; With scanning speeds of 100 ppm/200 ipm (200/300 dpi), the fi-7700 greatly improves process efficiency. Large volumes of information can be captured from various media, including thin paper, plastic cards, envelopes and long page documents.
Smooth paper flow; The fi-7700 automatically adjusts to paper weights from 20-413 g/m². The straight paper path reduces the load on a document and assures reliable scanning regardless of the condition and type of a document. By simply sliding a lever to non-separation mode, you can easily scan thick and long documents folded in half, multi-layered document sets and envelopes.
Innovative paper feeding mechanisms; Skew Reducer automatically handles sheets of paper in a stack individually, so that if one sheet is fed-in skewed, subsequent sheets are not forced into physical skew. This ensures that all information in the documents is captured correctly, even in batches with mixed document formats. The Paper Protection function monitors document movement and automatically stops feeding when any irregularities are detected.
Form follows function; The fi-7700's ADF unit slides to either side or rotates by 180 degrees. The LCD on the operation panel reveals the scanner status at a glance and enables instant operation.
Lower workload before and after scanning; The Automatic Document Feeder's (ADF) independent side guides move to exactly the position required for each batch. The adjustable stacker side guides support neat alignment of processed documents. The fi-7700 flatbed consecutively scans thick, fragile or bound documents even with the document cover open.
PaperStream IP and PaperStream Capture; The fi-7700 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture enhances the document capture process from adjusting scanning settings to performing batch scanning, verifying data and releasing to directories, repositories or subsequent process routines. Users can complete data capture tasks easily with the extremely user-friendly graphical user interface (GUI). Moving scanned batches into a queue for later retrieval is possible as well.
  • Efficient scanning
    The Ricoh fi-7700 document scanner delivers exceptional speed with up to 100 ppm in both color and black and white, ensuring your workflow remains uninterrupted.
  • Versatile media handling
    This scanner accommodates a wide range of document sizes, from small business cards to large A3 sheets and even long documents up to 5588 mm, making it ideal for various scanning needs.
  • Advanced image processing
    Features like Advanced DTC, Multi-Image Output, and automatic color detection work together to enhance image quality and accuracy, providing clear and precise scans every time.
  • Reliable paper feeding
    With a robust feeder capacity of 300 sheets and innovative functions like Ultrasonic multifeed sensor and Paper Protection Function, the fi-7700 ensures smooth and safe document handling.
  • Energy efficient
    ENERGY STAR certification and a power-efficient design, with a low power consumption in sleep mode, align with your eco-friendly office goals.
Ricoh fi-7700 - document scanner - desktop - USB 3.1 Gen 1
Document scanner - desktop
Interface Type
USB 3.1 Gen 1
Scanning Sensor Type
Triple CCD
Light Source
White LED array
Max Supported Document Size
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
304.8 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials), plastic card, envelope, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
30000 scans per day
AC 120/230 V
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
70.6 cm x 50 cm x 34.5 cm
35 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 3.1 Gen 1
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Triple CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
30000 scans per day
Scanner Speed Details
100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 0.6 sec/scan - landscape flatbed - A4 - 200 dpi , 0.6 sec/scan - landscape flatbed - A4 - 300 dpi , 80 ppm - portrait - A4 - 200 dpi , 80 ppm - portrait - A4 - 300 dpi , 160 ipm - duplex - portrait - A4 - 200 dpi , 160 ipm - duplex - portrait - A4 - 300 dpi , 0.9 sec/scan - portrait flatbed - A4 - 200 dpi , 0.9 sec/scan - portrait flatbed - A4 - 300 dpi
Scanner Features
Paper Protection Function, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, Barcode Detection, Ultrasonic multifeed sensor, automatic colour detection, Dither, Advanced DTC, Multi-Image Output, built-in LCD screen, RGB Color Dropout, Punch Hole Removal, Deskew, Blank Page Detection
TWAIN, ISIS
Media Handling
Max Document Size
304.8 mm x 5588 mm
Supported Document Size Details
ADF - up to 304.8 x 431.8 mm , Flatbed - up to ARCH B (304.8 x 457.2 mm) , Long document - up to 304.8 x 5588 mm
Automatic
300 sheets
Interfaces Details
USB 3.1 Gen 1 - Type B
ADF paper chute, stacker
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
64 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
1.7 Watt
Software Included
ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, 2D Barcode for PaperStream, Error Recovery Guide
System Requirements Details
Core i5 - 2.5 GHz - RAM 4 GB
70.6 cm
50 cm
34.5 cm
35 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
CW1N Fujitsu Extends Warranty From 1 Year to 3 Year For Low Volume Production Scanners - NBD Onsite In Stock £1,028.46
CW1N Fujitsu Extends Warranty to 3 Year with 8+8hrs On-Site Fix for Low Volume Scanners - Onsite 8 Hours In Stock £1,308.47
CW1N Fujitsu Extends Warranty 3 Years with Low Volume Production Scanners - 8+8hrs On-Site 1 x PM In Stock £2,616.93
CW1N Fujitsu Extends Warranty 3 Years Low Volume Production Scanners 8+8hrs On-Site 2 x PM In Stock £4,016.97
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: £1500+
