The fi-7300NX is an Image Scanner that supports web systems and connects directly to client systems. Users can begin scanning from the scanner's touch screen or from various applications on smart devices to suit all business needs. Not only is direct data transfer to client-unique web systems possible with SDK use, but secure data transfer is also possible with strong data encryption. The fi-7300NX boasts a speed of 60 ppm/120 ipm (200/300 dpi) for scanning A4 portraits, loads up to 80 sheets at a time, and ensures utmost efficiency as the first standalone scanner in the world to support 5 GHz Wi-Fi. The 4.3" touch screen enables users to perform operations intuitively, like scanning and data checking, with thumbnail reviews of scans and the screen also displays messages or instructions with illustrations so that users can handle errors themselves.
Users can scan and save documents without any requirement for a local computer, they can simply login to the scanner using user authentication and select a job from their personalized job menus on the fi-7300NX's touch screen. Customized job menus ensure efficient and secure decentralized data entry is possible for each user.
The fi-7300NX supports NFC (Type-A and Type-B) authentication and user authentication with username and password input on the touch screen. It is also possible for different job menus to be assigned to each scanner, and avoid any authentication processes. With PaperStream NX Manager, users can scan from mobile or web applications opened up on smart devices or thin client terminals. Seamless integration into company systems enables use of a variety of devices for scanning operations. The user authentication function, job menu, and other scan settings are all centrally managed with PaperStream NX Manager and Scanner Central Admin. With the fi-7300NX's server software, there is no need for the conventional single client computer to scanner environment and the system administrator to stand by the scanner. This reduces the total burden of installation, expansion, operation, and management. Manage jobs and process images with PaperStream NX Manager. Monitor scanner operation with Scanner Central Admin.
When scanning with computers, the fi-7300NX can be used with PaperStream IP, a specialized scanner driver for Fujitsu image scanners, via Wi-Fi connection, wired network, and USB connection. Connection without need for the USB cable allows the scanner to be positioned wherever needed, to improve user productivity, reduce interruptions, and make more room for more frequently used equipment.
Efficient scanning
With automatic duplexing and a feeder capacity of 80 sheets, this scanner is designed for efficiency, allowing for quick and easy document processing without constant manual intervention. -
High-quality imaging
The fi-7300NX boasts a color depth of 24-bit and a grayscale depth of 8-bit, producing sharp, vivid images with up to 16.7 million colors and 256 gray levels for detailed document scans. -
Versatile connectivity
Equipped with both USB 3.1 Gen 1 and Gigabit Ethernet interfaces, this scanner offers flexible connectivity options, ensuring seamless integration into any office environment. -
Advanced features
Features like the 4.3" touchscreen TFT display, NFC authentication, and Intelligent Sonic Paper Protection (iSOP) enhance user experience and document safety, making scanning tasks simpler and more secure. -
Eco-friendly operation
ENERGY STAR certification and a low power consumption design underscore the fi-7300NX's commitment to environmentally friendly operation, reducing energy costs and your organization's carbon footprint.
 - Ricoh fi-7300NX - document scanner - desktop - Gigabit LAN, USB 3.1 Gen 1
 - Document scanner - desktop
- Interface Type
- Scanning Sensor Type
 - Dual CCD
- Light Source
 - White LED array
- Max Supported Document Size
 - 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
 - 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
 - 600 dpi x 600 dpi
- Interpolated Resolution
 - 1200 dpi x 1200 dpi
- Max Document Scan Speed
 - 60 ppm (mono) / 60 ppm (colour)
- Max Document Size
 - 216 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
 - Plain paper, plastic card
- Document Feeder Type
 - Automatic
- Document Storage Capacity
 - 80 sheets
- Duty Cycle
 - 4000 scans per day
- Power
 - AC 120/230 V (50/60 Hz)
- System Requirements
 - Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
 - 30 cm x 20.2 cm x 17 cm
 - 4.9 kg
- Environmental Standards
 - ENERGY STAR Qualified
- Interface Type
 - 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
 - 24-bit (16.7 million colours)
 - 600 dpi x 600 dpi
 - Dual CCD
- Bulb / Light Source Type
 - White LED array
- Max Document Scan Speed B/W
 - 60 ppm
- Max Document Scan Speed Colour
 - 60 ppm
- Duty Cycle
- Scanner Speed Details
 - 60 ppm - portrait - A4 - 200 dpi , 60 ppm - portrait - A4 - 300 dpi , 120 ipm - duplex - colour - 200 dpi , 120 ipm - duplex - colour - 300 dpi , 120 ipm - duplex - greyscale - 200 dpi , 120 ipm - duplex - greyscale - 300 dpi , 120 ipm - duplex - black & white - 200 dpi , 120 ipm - duplex - black & white - 300 dpi
- Scanner Features
 - Built-in LCD screen, Ultrasonic sensor, Intelligent Sonic Paper Protection (iSOP), 4.3" touch screen TFT display, NFC authentication
 - TWAIN, ISIS
Media Handling
- Max Document Size
 - 216 mm x 5588 mm
 - Automatic
 - 80 sheets
- Interfaces Details
 - USB 3.1 Gen 1 , Gigabit LAN
- Included Accessories
 - ADF paper chute
- Cables Included
 - 1 x USB cable
 - RoHS
- ENERGY STAR Certified
- Power Device
 - External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
 - 42 Watt
- Power Consumption Stand by
 - 0.35 Watt
- Power Consumption Sleep
 - 2.4 Watt
- Software Included
 - ScanSnap Manager, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
 - 30 cm
 - 20.2 cm
 - 17 cm
 - 4.9 kg
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
