The fi-7280 document scanner from Fujitsu with ADF and flatbed is armed with a host of automated hardware and software based tools designed to make the job of scanning mixed batches of documents as seamless and hassle free as possible. Impressive scan speeds, industry leading paper protection mechanisms, status monitoring tools and bundled Fujitsu developed driver (PaperStream IP) and image enhancement software (PaperStream Capture) help ensure that the capture of your documents is done reliably and efficiently.
Efficient scanning
With automatic duplexing and a robust duty cycle of 6,000 scans per day, this desktop document scanner is designed to handle high-volume scanning with ease. Its 80-sheet feeder capacity further enhances productivity for busy office environments. -
Superior image quality
The Ricoh fi-7280 delivers exceptional image clarity with a color depth of 24-bit and grayscale depth of 8-bit, ensuring that your scanned documents retain all the nuances of the originals. The Triple CCD scanning sensor type and resolutions up to 600 DPI provide sharp, detailed images for all your scanning needs. -
Versatile connectivity
Equipped with a USB 3.0 interface, the scanner offers fast data transfer speeds, making it easy to connect to a PC. Its built-in LCD screen enhances user interaction, allowing for straightforward operation and monitoring of scanning tasks. -
Eco-friendly choice
This scanner is not only powerful but also environmentally conscious. With ENERGY STAR certification and EPEAT Silver compliance, it meets strict energy efficiency and environmental standards, making it an ideal choice for eco-conscious businesses.
- Ricoh fi 7280 - document scanner - desktop - USB 3.0
- Document scanner - desktop
- Interface Type
- USB 3.0
- Scanning Sensor Type
- Triple CCD
- Max Supported Document Size
- 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 80 ppm (mono) / 80 ppm (colour)
- Max Document Size
- 216 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Duty Cycle
- 6000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
- 30 cm x 57.7 cm x 23.4 cm
- 8.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 3.0
- 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Triple CCD
- Max Document Scan Speed B/W
- 80 ppm
- Max Document Scan Speed Colour
- 80 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ppm - colour - 200 dpi , 80 ppm - colour - 300 dpi , 80 ppm - greyscale - 200 dpi , 80 ppm - greyscale - 300 dpi , 80 ppm - black & white - 200 dpi , 80 ppm - black & white - 300 dpi , 160 ipm - duplex - colour - 200 dpi , 160 ipm - duplex - colour - 300 dpi , 160 ipm - duplex - greyscale - 200 dpi , 160 ipm - duplex - greyscale - 300 dpi , 160 ipm - duplex - black & white - 200 dpi , 160 ipm - duplex - black & white - 300 dpi , 1.7 sec/scan - landscape - 200 dpi
- Scanner Features
- Built-in LCD screen
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 5588 mm
- Plain paper
- Automatic
- 80 sheets
- Interfaces Details
- USB 3.0 - Type B
- RoHS
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 43 Watt (1.8 Watt)
- Software Included
- ScanSnap Manager, Scan to Microsoft SharePoint, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, Error Recovery Guide
- OS Required
- 30 cm
- 57.7 cm
- 23.4 cm
- 8.8 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Fujitsu Assurance Program Silver Extended Service Agreement 3 Years for fi-7x80 | In Stock | £133.53 |
Fujitsu Extends Warranty From 1 Year to 3 Year For Department Scanners- Inc Replacement and Shipping | In Stock | £172.37 |
Fujitsu Extends Warranty to 3 Years On-Site Fix for Departmental Scanners - Onsite Within 8 Hours | In Stock | £522.39 |
