Fujitsu fi-7260 Flatbed + Sheetfeed Scanner 30 x 57.7 x 23.4 cm
Quicklinx: 9C17WS00 Mfr#: PA03670-B551
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 355.6 mm
Interface: USB 3.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£1,015.07 ex VAT
£1,218.08 inc VAT
The fi-7260 document scanner from Fujitsu with ADF and flatbed is armed with a host of automated hardware and software based tools designed to make the job of scanning mixed batches of documents as seamless and hassle free as possible. Impressive scan speeds, industry leading paper protection mechanisms, status monitoring tools and bundled Fujitsu developed driver (PaperStream IP) and image enhancement software (PaperStream Capture) help ensure that the capture of your documents is done reliably and efficiently.
  • Fast and compact
    The fi-7260 has been introduced to support increasingly diverse business related document capture routines at the desktop of individual knowledge workers or small workgroups. Simple, productivity-boosting operation virtually eliminates training requirements.
  • Scan brochures and other small booklets
    The fi-7260 features an ultra fast built-in flatbed module that enables the scanning of diverse documents types such as bound, stapled or delicate documents.
  • Large volume hopper
    Featuring a high capacity hopper tray, these scanners allow for loading document batches containing up to 80 sheets at a time - and allowing for the continuous feeding of additional documents whilst scanning.
  • High-speed interface
    USB 3.0 support ensures high-speed data transfer between scanner and computer.
  • LCD status display and control panel
    A liquid crystal display (LCD) is included in the operator panel to display useful information including current settings for scanning documents, the number of sheets scanned, and error status. Users know the scanner status in the blink of an eye and can easily select and initiate predefined scanning profiles.
  • iSOP - intelligent Sonic Paper Protection
    Building on and incorporating the market-proven paper protection mechanisms of previous fi-series scanners, the fi-7260 introduces an additional market innovation for safeguarding any paper documents. By listening to the audible sound of paper movements, intelligent Sonic Paper Protection automatically suspends paper feeding if an irregular noise is detected. This advanced Paper Protection feature reliably reduces the risk of damaging documents during scanning.
  • Stable paper feeding with skew reduction
    The fi-7260 is equipped with a "Skew Reducer" to maintain the straight alignment of paper feeding. Particularly valuable for mixed document batches containing small format documents or thin paper sheets, this function reduces the physical skew of documents throughout the paper path. Even the most untidy batches are given special treatment sheet-by-sheet, which ensures total coverage for every scan: no lost data on the edges or in the corners, no more rescans.
Fujitsu fi-7260 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scanning Sensor Type
Triple CCD
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
4000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
30 cm x 57.7 cm x 23.4 cm
8.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Triple CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
60 ppm - colour - 200 dpi , 60 ppm - colour - 300 dpi , 60 ppm - greyscale - 200 dpi , 60 ppm - greyscale - 300 dpi , 60 ppm - black & white - 200 dpi , 60 ppm - black & white - 300 dpi , 120 ipm - duplex - colour - 200 dpi , 120 ipm - duplex - colour - 300 dpi , 120 ipm - duplex - greyscale - 200 dpi , 120 ipm - duplex - greyscale - 300 dpi , 120 ipm - duplex - black & white - 200 dpi , 120 ipm - duplex - black & white - 300 dpi , 1.7 sec/scan - landscape - 200 dpi
Scanner Features
Built-in LCD screen
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Plain paper
Automatic
80 sheets
USB 3.0 - Type B
RoHS
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
41 Watt (1.8 Watt)
Software Included
ScanSnap Manager, Scan to Microsoft SharePoint, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, Error Recovery Guide
30 cm
57.7 cm
23.4 cm
8.8 kg
5 °C
35 °C
20 - 80% (non-condensing)
9C17 Fujitsu Extends Warranty From 1 Year to 3 Year For WorkGroup Scanners - Inc Replacement and Shipping In Stock £95.10
9C17 Fujitsu Extends Warranty to 3 Year for Workgroup Scanners - 8hrs On-Site + 8hrs Fix In Stock £313.47
Interface: USB 3.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: £1000 - £1500
