Fujitsu fi-7240 Duplex Document Scanner
Quicklinx: C38HWS00 Mfr#: PA03670-B601
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 355.6 mm
Interface: USB 2.0
Compatibility: PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£837.80 ex VAT
£1,005.36 inc VAT
Outstanding performance starts with reliable, compact hardware technology automatically supported by intuitive routines.
The sleek and compact 40 double sided pages per minute fi-7240 desktop ADF and flatbed scanner from Fujitsu allows for merging paper document content with digitally born data. Enjoy the introduction of optimum quality from automated document capture and increase the breadth of document management related activities such as invoice and forms processing, archiving and workflow. Flexibly fit this document capture solution to existing and emerging tasks such as current mail delivery methods or addressing regulatory concerns.
Fujitsu fi-7240 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Triple CCD
Light Source
White LED array
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Ubuntu 16.04
57.7 cm x 30 cm x 23.4 cm
8.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Triple CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Scanner Speed Details
40 ppm - colour - 200 dpi , 40 ppm - colour - 300 dpi , 40 ppm - greyscale - 200 dpi , 40 ppm - greyscale - 300 dpi , 40 ppm - black & white - 200 dpi , 40 ppm - black & white - 300 dpi , 80 ipm - duplex - colour - 200 dpi , 80 ipm - duplex - colour - 300 dpi , 80 ipm - duplex - greyscale - 200 dpi , 80 ipm - duplex - greyscale - 300 dpi , 80 ipm - duplex - black & white - 200 dpi , 80 ipm - duplex - black & white - 300 dpi
Scanner Features
Color Dropout, Dynamic Threshold, Error Diffusion, automatic colour detection, automatic page size detection, Simplified DTC, Advanced DTC, Multi-Image Output, Punch Hole Removal, Deskew, Blank Page Detection
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Supported Document Size Details
ADF - up to 216 x 355.6 mm , Long document - up to 210 x 5588 mm
Automatic
80 sheets
USB 2.0 - Type B
Directive 2002/95/EC
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
38 Watt
Software Included
ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
57.7 cm
30 cm
23.4 cm
8.8 kg
5 °C
35 °C
20 - 80% (non-condensing)
C38H Fujitsu 5x Carrier Sheets for ScanSnap In Stock £34.31
C38H Fujitsu Extends Warranty From 1 Year to 3 Year For WorkGroup Scanners - Inc Replacement and Shipping In Stock £77.59
C38H Fujitsu Extends Warranty to 3 Year for Workgroup Scanners - 8hrs On-Site + 8hrs Fix In Stock £259.60
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 750 - 1000
