Fujitsu fi-7140 A4 Document Scanner
Quicklinx: C38GWS00 Mfr#: PA03670-B101
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 355.6 mm
Interface: USB 2.0
Compatibility: PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£425.95 ex VAT
£511.14 inc VAT
Outstanding performance starts with reliable, compact hardware technology automatically supported by intuitive routines.
The sleek and compact 40 double sided pages per minute fi-7140 desktop ADF scanner from Fujitsu allows for merging paper document content with digitally born data. Enjoy the introduction of optimum quality from automated document capture and increase the breadth of document management related activities such as invoice and forms processing, archiving and workflow. Flexibly fit this document capture solution to existing and emerging tasks such as current mail delivery methods or addressing regulatory concerns.
  • Outstanding paper feeding delivers reliable batch scanning regardless of the document condition
    These scanners allow the user to scan a wide variety of paper thicknesses (27 to 413 g/m2), as well as plastic cards with the same feeding mechanism inherited from high-end models. In addition, Paper Protection constantly checks along the whole document length during scanning and automatically stops paper feeding when error occurs to avoid any damage to the document. All in all these deliver the reliable scanning experience expected from Fujitsu.
  • Reliable Skew Reducer even when scanning a mixed size batch
    The fi-7140 automatically detects the document size when scanning a mixed size batch. Furthermore, it is equipped with Skew Reducer to detect the alignment of scanned documents and correct paper skews to minimize missing the edge of the scanned image. Users can rest assured that the result will be good even when scanning documents that are not aligned correctly.
  • Compact design for fast scanning right at your desk
    The fi-7140 is a compact model that can be placed on the desk, whether for overthe- counter service or for operations in office. It scans at a speed of 40 ppm (A4, color, 200/300 dpi). Simply press the scan button and it will start scanning within a second. Scanning with the fi-7140 will not keep you, or your customers, waiting.
  • Automatically creates the most suitable high quality image data for OCR process
    The PaperSteam IP scanner driver, which supports TWAIN/ISIS, saves the inconvenience of fine adjusting the settings for the OCR process. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled or soiled documents or documents with a background pattern.
Fujitsu fi-7140 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
White LED array
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04
30 cm x 17 cm x 16.3 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Scanner Speed Details
40 ppm - colour - 200 dpi , 40 ppm - colour - 300 dpi , 40 ppm - greyscale - 200 dpi , 40 ppm - greyscale - 300 dpi , 40 ppm - black & white - 200 dpi , 40 ppm - black & white - 300 dpi , 80 ipm - duplex - colour - 200 dpi , 80 ipm - duplex - colour - 300 dpi , 80 ipm - duplex - greyscale - 200 dpi , 80 ipm - duplex - greyscale - 300 dpi , 80 ipm - duplex - black & white - 200 dpi , 80 ipm - duplex - black & white - 300 dpi
Scanner Features
Color Dropout, Dynamic Threshold, Error Diffusion, automatic colour detection, automatic page size detection, Simplified DTC, Advanced DTC, Multi-Image Output, Punch Hole Removal, Deskew, Blank Page Detection
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Supported Document Size Details
ADF - up to 216 x 355.6 mm , Long document - up to 216 x 5588 mm
Automatic
80 sheets
Interfaces Details
USB 2.0 - Type B
RoHS
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
36 Watt
Software Included
ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
30 cm
17 cm
16.3 cm
4.2 kg
5 °C
35 °C
20 - 80% (non-condensing)
C38G Fujitsu Extends Warranty From 1 Year to 3 Year For WorkGroup Scanners - Inc Replacement and Shipping In Stock £85.70
C38G Fujitsu Extends Warranty to 3 Year for Workgroup Scanners - 8hrs On-Site + 8hrs Fix In Stock £282.51
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
