The Fujitsu fi-6800 offers fast 130ppm/260ipm, A4 landscape colour scanning with a device that has been developed with a completely new and unique compact design. The design includes both unique image handling hardware and hardware accelerated 'VRS Professional' factory mounted, the user receives a complete high performance capture solution right out of the box. Operators will begin making professional scans in no time.
A new compact design that sure to please users.
Utilizing a high quality lens and extra bright LED light source enclosed in a heavy duty resin frame. The fi-6800s new compact design makes it the smallest document scanner in its class. It takes up 53% less space and is 72% lighter than its predecessor.
Supporting the Operator
-The fi-6800 is ergonomically designed to facilitate scanning whether the operator is standing or seated.
S-canner status and settings are presented and controlled on an easy to navigate LCD panel.
-Simple but very sturdy construction with a wide flip up cover for easy access and obstacle free cleaning.
-Near silent operation allows for front or back office placement in support of a multitude of professional business scanning tasks.
New functions that boost automation and increase productivity
The fi-6800 supports many new automatic functions that simplify your scanning tasks and maximise operator productivity.
Route files with ease, using Patch code or barcode supported job separation
fi-6800 features patch code and barcode recognition functions, Whenever detected, files can be automatically routed to new subdirectories to expidite and automate post capture processing routines. If using barcodes the files and directories can even be named based on the information contained in the barcode. Combined with the images capture software ScandAll PROs automatic sorting function, scanning sorting and saving can be a hands free operation.
Reduce the hassle of post scan tasks
Automatic stacker ensures all your scanned documents are neatly stacked, while an Automatic Image Quality Checker detects an image irregularities i.e. folds or tears in the original document, after scanning. Post scanning tasks have never been this easy.
An improved paper feed mechanism which protects against document damage or misaligned feeds
Fujitsu's fi-6800 features a very reliable paper feed mechanism which is derived from Fujitsu's top-of-the-line fi-5900C model. Utilising fi-series renowned "Paper Protection" and "Multi Feed Protection" functions, paper feed problems are tackled before they happen. This ensures optimum workflow to your business and maximum uptime for the scanner.
Short recovery from sleep mode due to use of extra bright LED source (within 6 seconds)
Going easy on our environment (Green IT)
Low power consumption when in sleep mode (less than 4 watts)
Constructed using minimum quantities and lightweight raw materials
A revolutionary, green design
The fi-6800 has been constructed from carefully selected raw materials in favor of ecology. The recovery time from the extra-bright LED light source is less than six seconds and the device have a power consumption of less than 4W while in sleep mode, meaning that demands on energy are kept as low as possible. The ultra-bright LED lamp technology incorporated into the design helps decrease power consumption while reducing the warm-up time before starting to scan. Upon power-on, the scanner is ready to start operating within seconds, making it ideal when small batches of documents need to be scanned at frequent intervals throughout the day. -
Unrivaled performance and value for money
The fi-6800 comes equipped with PaperStream IP and PaperStream Capture, enabling incredibly advanced image processing at high speed. With an excellent quality lens and extra-bright LED light source on board, end users will receive a complete high performance capture device that efficiently supports simple batch scanning jobs right out of the box. For more sophisticated capture requirements, the fi-6800 integrates seamlessly into Enterprise Content Management and Document Management solutions. -
Hassle-free usability
The fi-6800 has been designed with usability in mind, and allows the user or operator to conveniently adapt the scanner to their habits, processes and preferences. Scanner status and settings are presented and changed on an easy to navigate LCD panel, which allows even complex capture routines to be completed from pre-defined and panel assigned profiles. Near-silent operation allows for both back and front office placement, while the scanner's simple yet sturdy construction and wide flip-up cover allow for easy access and obstacle-free cleaning.
- Fujitsu fi-6800 - document scanner - desktop - USB 2.0, SCSI
- Document scanner - desktop
- Interface Type
- USB 2.0, SCSI
- Scanning Sensor Type
- Dual CCD
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 130 ppm (mono) / 130 ppm (colour)
- Max Document Size
- 305 mm x 432 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 500 sheets
- Duty Cycle
- 60000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows 7, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 46 cm x 43 cm x 31 cm
- 32 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0, SCSI
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- 600 dpi x 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CCD
- Max Document Scan Speed B/W
- 130 ppm
- Max Document Scan Speed Colour
- 130 ppm
- Duty Cycle
- Scanner Speed Details
- 130 ppm - black & white - A4 , 130 ppm - colour - A4 , 260 ipm - duplex - black & white - A4 , 260 ipm - duplex - colour - A4
- Scanner Features
- Ultrasonic Double Feed Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- 305 mm x 432 mm
- Plain paper
- Automatic
- 500 sheets
- Interfaces Details
- Ultra SCSI - HD-50 , USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- RoHS
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 200 Watt (4 Watt)
- Software Included
- Drivers & Utilities, Adobe Acrobat, Kofax VirtualReScan Professional, ScandAll PRO with Scan to Microsoft SharePoint, QuickScan Pro (Trial), Image Processing Software Option (Trial)
- OS Required
- 46 cm
- 43 cm
- 31 cm
- 32 kg
- 15 °C
- 35 °C
- 20 - 80%
