Fujitsu fi-6800 A3 Duplex Document Scanner with Paperstream
Quicklinx: C38QWS00 Mfr#: PA03575-B061
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The fast and intuitive FUJITSU Image Scanner fi-6800 mid-volume scanner brings significant operating benefits to paper intensive organizations. A unique compact design provides users with a solution that is ready to improve productivity without delay. Rapid start up time, smooth paper flow and ease of use all contribute to an efficient end-to-end image capture process and powerful software ensures document preparation and post-scan procedures are minimized.
Automated routines deliver a performance bonus to document-hungry businesses when archiving records, satisfying compliance requirements and introducing ad hoc documents to workflows. The result is a robust scanner that reduces the total cost of ownership and provides a fast return on investment.
Convert large volumes of documents with speed and dependable throughput every day. The fi-6800 minimizes operator alerts through a host of automated functionalities to provide uninterrupted performance when processing large batches of documents.
Operators can manage mixed document batches efficiently when the physical characteristics of documents change within the batch. The fi-6800 handles different sized sheets from A8 to A3 and differences in materials such as when paper, card and plastic vary in weight and thickness - leaving the operator free to attend to parallel tasks without being distracted by avoidable misfeed alerts.
The bundled PaperStream IP driver takes the work out of image cleanup when scanning invoices, ID cards, receipts, forms, or any other day to day paperwork. PaperStream IP automatically improves the image quality, removes unwanted backgrounds, and optimizes your scanned images for optical character recognition. It is fast and easy to use. The latest innovation, Assisted Scan, allows users to replace poor images by visually selecting the image they lack rather than learning driver settings. If driver settings need to be adjusted for rare and difficult documents, a preview function allows scan operators to see their adjustments in real-time without time consuming re-scans. PaperStream IP works with both ISIS and TWAIN applications.
The bundled PaperStream Capture makes advanced capture with Fujitsu scanners easier than before. PaperStream Capture has a streamlined User Interface to reduce training time and increase productivity. Not only has FUJITSU provided users with the most common profiles used by customers - black and white, color, and auto-color - new profiles are easily created or modified through a wizard. FUJITSU has organized the release screen so that batches can easily be suspended or continued. PaperStream Capture is also integrated with PaperStream IP's assisted scanning for visual cleanup of documents. The reading of barcodes and patch codes make batch separation easy, improving document organization.
  • A revolutionary, green design
    The fi-6800 has been constructed from carefully selected raw materials in favor of ecology. The recovery time from the extra-bright LED light source is less than six seconds and the device have a power consumption of less than 4W while in sleep mode, meaning that demands on energy are kept as low as possible. The ultra-bright LED lamp technology incorporated into the design helps decrease power consumption while reducing the warm-up time before starting to scan. Upon power-on, the scanner is ready to start operating within seconds, making it ideal when small batches of documents need to be scanned at frequent intervals throughout the day.
  • Unrivaled performance and value for money
    The fi-6800 comes equipped with PaperStream IP and PaperStream Capture, enabling incredibly advanced image processing at high speed. With an excellent quality lens and extra-bright LED light source on board, end users will receive a complete high performance capture device that efficiently supports simple batch scanning jobs right out of the box. For more sophisticated capture requirements, the fi-6800 integrates seamlessly into Enterprise Content Management and Document Management solutions.
  • Hassle-free usability
    The fi-6800 has been designed with usability in mind, and allows the user or operator to conveniently adapt the scanner to their habits, processes and preferences. Scanner status and settings are presented and changed on an easy to navigate LCD panel, which allows even complex capture routines to be completed from pre-defined and panel assigned profiles. Near-silent operation allows for both back and front office placement, while the scanner's simple yet sturdy construction and wide flip-up cover allow for easy access and obstacle-free cleaning.
Fujitsu fi-6800 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scanning Sensor Type
Dual CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
130 ppm (mono) / 130 ppm (colour)
Max Document Size
305 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
500 sheets
Duty Cycle
60000 scans per day
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
46 cm x 43 cm x 31 cm
32 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
130 ppm
Max Document Scan Speed Colour
130 ppm
Duty Cycle
60000 scans per day
Scanner Speed Details
130 ppm - black & white - A4 , 130 ppm - colour - A4 , 260 ipm - duplex - black & white - A4 , 260 ipm - duplex - colour - A4
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
305 mm x 432 mm
Plain paper
Automatic
500 sheets
Interfaces Details
Ultra SCSI - HD-50 , USB 2.0 - Type B
1 x USB cable
RoHS
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
AC 120/230 V
Power Consumption Operational (Standby)
200 Watt (4 Watt)
Software Included
ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
46 cm
43 cm
31 cm
32 kg
15 °C
35 °C
20 - 80%
