The compact, lightweight fi-65F scanner is ideal for busy office and retail environments. It quickly scans important, small documents like passports, IDs, prescriptions, driving licences, customer and medical cards and photographs, and seamlessly integrates with virtually any line of business application (LoB).
Energy efficient
With its ENERGY STAR certification, this flatbed scanner meets strict energy efficiency guidelines, ensuring lower energy costs and a reduced environmental footprint. -
Versatile scanning
Equipped with a manual document feeder and the ability to scan a wide range of document sizes up to A6, this scanner is designed for flexibility in handling various document types and sizes. -
High-quality imaging
Featuring a color depth of 24-bit and grayscale depth of 8-bit, the scanner produces high-quality images with up to 600 DPI resolution, capturing every detail with precision. -
Fast and efficient
Achieve rapid scanning speeds with the device's ability to scan A6 documents in as little as 1 second in grayscale and B&W modes, and 1.7 seconds in color mode when AC powered. -
Compact and portable
Its desktop form factor combined with USB power option makes it a compact and portable solution, ideal for users who need a high-performance scanner that occupies minimal space.
- Ricoh fi-65F - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- RGB LED array
- Max Supported Document Size
- A6 (105 x 148 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels)
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Size
- 105 mm x 148 mm
- Document Feeder Type
- Manual
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
- 14.5 cm x 23.4 cm x 4 cm
- 900 g
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- A6 (105 x 148 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Bulb / Light Source Type
- RGB LED array
- Scanner Speed Details
- 1.7 sec/scan - portrait colour (AC powered) - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 300 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 300 dpi , 2 sec/scan - portrait colour (USB bus powered) - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 300 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 300 dpi
- Scanner Features
- Powered by USB port
- TWAIN, ISIS
Media Handling
- Max Document Size
- 105 mm x 148 mm
- Manual
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 8 Watt (2 Watt)
- Software Included
- Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 14.5 cm
- 23.4 cm
- 4 cm
- 900 g
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
