The FUJITSU Image Scanner fi-5950 production scanner is the paper-to-digital highway that minimizes human interaction with dependable pre to post scan automation. Excellent sheet handling functions and reliable paper processing performance support continuous and efficient mixed batch processing. Operators can incorporate the advanced image enhancement functions and experience high speed processing - essential for productive batch scanning. Fujitsu image enhancement, paper processing and automated procedures result in measurable business advantages when used for production and ad hoc image capture and high-volume archiving.
When faced with large daily demands, document capture bureaus and busy departments can respond with streamlined efficiency. At up to 135 (A4 landscape) pages per minute (ppm) or 270 images per minute (ipm) at 300 dpi resolution and an array of powerful image enhancing and paper-feed functions the fi-5950 can shrink the operator's workload before, during and after scanning.
The bundled PaperStream IP driver takes the work out of image cleanup when scanning invoices, ID cards, receipts, forms, or any other day to day paperwork. PaperStream IP automatically improves the image quality, removes unwanted backgrounds, and optimizes your scanned images for optical character recognition. It is fast and easy to use. The latest innovation, Assisted Scan, allows users to replace poor images by visually selecting the image they lack rather than learning driver settings. If driver settings need to be adjusted for rare and difficult documents, a preview function allows scan operators to see their adjustments in real-time without time consuming re-scans. PaperStream IP works with both ISIS and TWAIN applications.
The bundled PaperStream Capture makes advanced capture with Fujitsu scanners easier than before. PaperStream Capture has a streamlined User Interface to reduce training time and increase productivity. Not only has FUJITSU provided users with the most common profiles used by customers - black and white, color, and auto-color - new profiles are easily created or modified through a wizard. FUJITSU has organized the release screen so that batches can easily be suspended or continued. PaperStream Capture is also integrated with PaperStream IP's assisted scanning for visual cleanup of documents. The reading of barcodes and patch codes make batch separation easy, improving document organization.
- Fujitsu fi-5950 - document scanner - desktop - USB 2.0, SCSI
- Document scanner - desktop
- Interface Type
- USB 2.0, SCSI
- Scanning Sensor Type
- Dual CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey / 24-bit (16.7 million colours)
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 135 ppm (mono) / 135 ppm (colour)
- Max Document Size
- 305 mm x 3048 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 500 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
- 54 cm x 54 cm x 50 cm
- 50 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0, SCSI
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Max Document Scan Speed B/W
- 135 ppm
- Max Document Scan Speed Colour
- 135 ppm
- Scanner Speed Details
- 135 ppm - black & white - A4 , 135 ppm - colour - A4 , 270 ipm - duplex - black & white - A4 , 270 ipm - duplex - colour - A4
- Scanner Features
- Ultrasonic multifeed sensor
- TWAIN, ISIS
Media Handling
- Max Document Size
- 305 mm x 3048 mm
- Plain paper
- Automatic
- 500 sheets
- Ultra Wide SCSI - HD-68 , USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- RoHS
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- OS Required
- 54 cm
- 54 cm
- 50 cm
- 50 kg
- 15 °C
- 35 °C
- 20 - 80%
Fujitsu Extends Warranty From 1 Year to 3 Year For Low Volume Production Scanners - Onsite NBD | In Stock | £2,729.64 |
Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8+8hrs On-Site 1 x PM | In Stock | £3,189.29 |
Fujitsu Extends Warranty 3 Years Low Volume Prodcution Scanners - 8hrs On-Site 8hrs Fix 2 xPM | In Stock | £4,348.06 |
