Fujitsu FI-5530C2 A3 SCANNER VRS 4.1
Quicklinx: 7DM8WS00 Mfr#: PA03334-B601
The Fujitsu fi-5530C2 Scanner offers an impressive feature set in a compact package and high performance scanning for demanding users. The fi-5530C2 is an A3 scanner that handles a vigorous duty cycle of up to 4,000 documents per day.
What's more, it scans at speeds up to 50 ppm / 100 ipm (landscape, 200 dpi), features dual color CCDs with true, 600-dpi resolution for capturing subtle details, and uses ultrasonic double-feed detection for reliable, automatic scanning. For greater ease-of-use, the fi-5530C2 includes a 100-page automatic document feeder (ADF) that handles documents ranging from A8 to A3 in size. For simplified connectivity the Fujitsu fi-5530C2 features a dual-interface, including ports for Ultra SCSI and high-speed USB 2.0 connections.
The fi-5530C2 is bundled with Adobe Acrobat Standard software, which converts documents to cross-platform Adobe Portable Document Format (PDF) files. And with the image enhancement capabilities provided with Kofax VRS and the advanced features included with new ScandAll Pro, the fi-5530C2 combines excellent handling performance with improved content control to deliver exceptional scanning results at an amazing value.
Fujitsu fi-5530C2 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scanning Sensor Type
CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
35 ppm (mono) / 35 ppm (colour)
Max Document Size
297 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
2500 scans per day
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista
39.9 cm x 22.5 cm x 19.3 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
CCD
Max Document Scan Speed B/W
35 ppm
Max Document Scan Speed Colour
35 ppm
Duty Cycle
2500 scans per day
Scanner Speed Details
35 ppm - black & white , 35 ppm - colour , 70 ipm - duplex - black & white , 70 ipm - duplex - colour
TWAIN, ISIS
Media Handling
Max Document Size
297 mm x 863 mm
Plain paper
Automatic
100 sheets
Interfaces Details
USB 2.0 - Type B , Ultra SCSI
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
57 Watt (7.5 Watt)
Software Included
Drivers & Utilities, Adobe Acrobat, Kofax VirtualReScan 4.1 Basic, ScandAll Pro
39.9 cm
22.5 cm
19.3 cm
8.5 kg
5 °C
35 °C
20 - 80%
