Fujitsu FI-5015C A4 Scanner
Quicklinx: 4HHFWS00 Mfr#: PA03209-B501
The fi-5015C image scanner from Fujitsu with a USB interface offers high speed, simplex color scanning capabilities within a compact body making it an ideal solution for decentralized scanning applications.
The fi-5015C can be customized to scan directly to email, ftp, print, Adobe PDF, or view with hardware profiles.
Equipped with a powerful 600-dpi true optical resolution CCD sensor, the Fujitsu fi-5015C dual feed scanner captures your document's finest details in both 24 bit color and monochrome. The fi-5015C automatic scanner also features an operator panel allowing effortless scanning directly to print, an email attachment, FTP, Adobe PDF, network share, or to your viewer.
Adobe Acrobat Standard and ScandAll Pro are included with the Fujitsu fi-5015C scanner, which allow you to quickly and easily integrate it into your workflow.
  • Customize the Fujitsu fi-5015C to scan directly to email, ftp, print, Adobe PDF, or view with hardware profiles
    The Fujitsu fi-5015C scanner's small footprint and advanced feature set make it an ideal solution for decentralized scanning applications.
  • Fast, flexible, reliable scanning performance
Fujitsu fi-5015C - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
15 ppm (mono) / 15 ppm (colour)
Max Document Size
216 mm x 356 mm
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista
44.5 cm x 33.2 cm x 17.9 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
CCD
Max Document Scan Speed B/W
15 ppm
Max Document Scan Speed Colour
15 ppm
Scanner Speed Details
15 ppm - colour - 150 dpi , 15 ppm - black & white - 200 dpi , 15 ppm - greyscale - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
24 Watt (6 Watt)
Software Included
44.5 cm
33.2 cm
17.9 cm
5.5 kg
5 °C
35 °C
10 - 85%
