This cleaning kit can be used to maintain your scanner for optimum performance, containing 72 specially formulated F1 cleaning fluid impregnated wipes. It effectively removes dirt, toner, carbon, chemicals from treated papers and other debris from the parts of the scanner that are in contact with the paper.
- Ricoh F1 Scanner Cleaning Wipes - cleaning wipes
- Product Type
- Cleaning wipes
- Packaged Quantity
- 72 (specifications are for single item)
- Designed For
- Fujitsu SP-1120, SP-1125, SP-1130, SP-1425; fi-5015, 5530, 6110, 6130, 6140, 6230, 6240, 65, 7030, 7140, 7160, 7180, 7240, 7260, 7280, 7300, 7460, 7480, 800, 8150, 8170, 8190, 8250, 8270, 8290; Network Scanner N7100; ScanPartner SP30; ScanSnap N1800
- Packaged Quantity
- Product Type
- Cleaning wipes
- Designed For
- Fujitsu SP-1120, SP-1120N, SP-1125, SP-1125N, SP-1130, SP-1130N, SP-1425 , Fujitsu fi-5015C, 5530C2, 6110, 6130Z, 6140Z, 6230Z, 6230ZLA, 6240Z, 65F, 7030, 7140, 7160, 7180, 7240, 7260, 7280, 7300NX, 7460, 7480, 800R, 8150, 8170, 8190, 8250, 8270, 8290 , Fujitsu Network Scanner N7100, N7100A , Fujitsu ScanPartner SP30F , Fujitsu ScanSnap N1800
