This cleaning kit can be used to maintain your scanner for optimum performance, containing 72 specially formulated F1 cleaning fluid impregnated wipes. It effectively removes dirt, toner, carbon, chemicals from treated papers and other debris from the parts of the scanner that are in contact with the paper.
Efficient cleaning
Designed specifically for scanners, these cleaning wipes offer an efficient solution to maintain your device's cleanliness and performance. Suitable for daily use, they help in removing dust, fingerprints, and smudges without leaving residue. -
Safe for use
The Ricoh F1 Scanner Cleaning Wipes are formulated to be safe on scanner surfaces, ensuring that your equipment remains unharmed during the cleaning process. Their gentle composition makes them ideal for regular maintenance of your valuable scanning equipment.
- Ricoh F1 Scanner Cleaning Wipes - cleaning wipes
- Product Type
- Cleaning wipes
- Packaged Quantity
- 72 (specifications are for single item)
- Designed For
- Ricoh fi-7300, 7460, 7480, 800, 8150, 8170, 8190, 8250, 8270, 8290, SP-1120, 1125, 1130, 1425; fi 65, 7030, 7160, 7240, 7280, 7300, 7460, 7480, 7800, 800, 8150, 8170, 8190, 8250, 8270, 8290; Image Scanner N7100; IS 800; ScanSnap iX100, iX1300, iX1400, iX1600, S1100, SV600
- Packaged Quantity
- Product Type
- Cleaning wipes
- Designed For
- Ricoh fi-7300NX, fi-7460, fi-7480, fi-800R, fi-8150, fi-8170, fi-8190, fi-8250, fi-8270, fi-8290, SP-1120N, SP-1125N, SP-1130N, SP-1130Ne, SP-1425 , Ricoh fi 65F, 7030, 7160, 7240, 7280, 7300NX, 7460, 7480, 7800, 800R, 8150, 8150U, 8170, 8170 TAA, 8190, 8190 FADGI Bundle, 8250, 8270, 8290, 8290 FADGI Bundle , Ricoh Image Scanner N7100E , Ricoh IS 800C , Ricoh ScanSnap iX100, iX1300, iX1400, iX1600, iX1600 Chromebook Edition, S1100i, SV600
