Fujitsu Esprimo X956 Intel Core i3-6100T 4GB 500GB Windows 10 Home
Quicklinx: BZQHWS00 Mfr#: VFY:X9560P83ACGB
  • Core i3
The sophisticated FUJITSU ESPRIMO X956 All-in-One PC has all the advantages of a PC plus a multi-position 23-inch LED display and innovative face recognition for easy log on. Achieve significant TCO savings with DeskView and Intel vPro technology and protect confidential data with the latest TPM controller. With the Low Power Active mode it supports a wide range of usage scenarios such as telephony and video conferencing.
  • Human centric
    This PC features a 23-inch widescreen IPS panel with its adjustable display provides an ideal working position.
  • Sleek, elegant design
    Industrial design addressing 21st century office requirements and style.
  • Enhanced usability
    Multi-functional sensors for videoconferencing.
Fujitsu ESPRIMO X956 - all-in-one - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB - LED 23" - UK
Personal computer - all-in-one
Region: United Kingdom
Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 3Gb/s - 5400 rpm
Optical Storage
No optical drive
Monitor
23" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
GigE
Keyboard
OS Provided
Windows 10 Home 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Windows 10 Home 64-bit recovery DVD
53.3 cm x 22.4 cm x 41.9 cm
5.94 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers, display
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q170
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
LED - IPS
Diagonal Size
23"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.265 mm
Response Time
14 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
10000000:1
Monitor Features
Anti-glare, High Frame Rate Control (Hi-FRC)
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Tilt wheel
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
2 (total) / 1 (free) x SO-DIMM 260-pin , 2 (total) / 2 (free) x M.2 Card
1 x audio line-out/headphones , 1 x audio line-in/microphone , 6 x USB 3.0 , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus
Power supply
Power Provided
90 Watt
Efficiency
92% at 100% Load, 87% at 20% Load, 86% at 10% Load, 91% at 50% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
53.3 cm
22.4 cm
41.9 cm
5.94 kg
10 °C
35 °C
5 - 85%
