The Fujitsu ESPRIMO Q556, featuring full desktop PC functionality in a stylish and compact mini PC, is a real eye-catcher on your desk. Its advanced processor provides the performance to meet your daily office needs. The Zero Noise PC function ensures silent operation. An integrated efficient power supply reduces your energy bill. With its alternative Low Power Active mode you are ready for instant communication. Its compact interface makes the Fujitsu ESPRIMO Q556 your first choice for locations where space saving is a key.
An elegant mini PC for challenging office tasks
With its eye-catching exclusive design this PC is fully equipped and based on standard desktop technology. -
Stay connected and save power
Be ready for instant communication and a significantly reduced energy bill with the alternative Low Power Active mode and highly-efficient integrated power-supply. -
Superb usability
Thanks to horizontal or vertical operations you have an efficient working environment.
- Fujitsu ESPRIMO Q556 - mini PC - Core i3 6100T 3.2 GHz - 8 GB - SSD 128 GB - UK
- Personal computer - mini PC
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Shared Video Memory (UMA)
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
- Software Included
- Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Fujitsu DeskUpdate, Windows 7 Professional (32/64 bits) / Windows 10 Pro 64-bit Twin-Pack recovery DVD
- 18.6 cm x 19.1 cm x 5.5 cm
- 1.6 kg
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- PS/2
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Scroll
- Ethernet Controller
- Realtek RTL8111GN
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card
- 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in/microphone (1 in front) , 2 x USB 2.0 (2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
- Power supply
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
- OS Provided
- Software
- 18.6 cm
- 19.1 cm
- 5.5 cm
- 1.6 kg
- 10 °C
- 35 °C
- 5 - 85%
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £25.26 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
