The Fujitsu PC ESPRIMO Q520, featuring full desktop PC functionality in a stylish and compact housing, is a real eye-catcher on your desk. Intel processors deliver the performance to meet your daily office needs. The Zero Noise functionality guarantees silent operation. An integrated 90%-efficient power supply cuts your energy bill. The Low Power Active Mode provides businesses with a wide range of usage scenarios like telephony and video conferencing. Its compact size and wide range of interfaces make the Fujitsu PC ESPRIMO Q520 your first choice for locations where space saving is key.
An elegant mini PC for challenging office tasks
Eye-catcher on every desk with a modern and exclusive design. -
Always available office PC
Provides businesses with a wide range of usage scenarios like telephony and video conferencing. Combines availability with energy saving. The PC looks like it is off but background application tasks can still run in the Low Power Active Mode. -
Superb usability
Pleasant working environment due to a tidy desk. Horizontal or vertical operations. -
Latest technology
Get your office job done fast and reliable.
- Fujitsu ESPRIMO Q520 - mini PC - Pentium G3220T 2.6 GHz - 4 GB - HDD 320 GB - QWERTY UK
- Personal computer - mini PC - administrator password, system password, hard drive password, USB port control, wake on LAN
- Localisation
- Region: United Kingdom
- Processor
- Intel Pentium G3220T / 2.6 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 3 MB L3 Cache
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 320 GB - SATA 3Gb/s
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- Intel HD Graphics Shared Video Memory (UMA)
- Audio Output
- Integrated
- Networking
- GigE, Bluetooth, 802.11b/g/n
- Keyboard
- QWERTY UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition
- Software Included
- Drivers & Utilities, Adobe Reader, Fujitsu Recovery, McAfee Multi Access (60 days trial), Workplace Protect
- 18.5 cm x 18.8 cm x 5.4 cm
- 1.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- Mini PC
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.6 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- L3 Cache - 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 320 GB
- Interface Type
- SATA 3Gb/s
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- VGA, DVI, DisplayPort
- HDCP Compatible
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- USB
- Localization & Layout
- QWERTY UK
Mouse
- Technology
- Optical
- Interface
- USB
- Scroll
- Integrated
- Ethernet Controller
- Intel I217-LM
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- DMI 2.0
- Wake on LAN (WoL), PXE support
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Bays
- 1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 memory
- 1 x audio line-out/headphones , 1 x audio line-in/microphone , 4 x USB 2.0 , 2 x USB 3.0 , 1 x DisplayPort , 1 x DVI-I , 1 x LAN (Gigabit Ethernet)
- Cables Included
- DVI-VGA adapter
- Administrator password, system password, hard drive password, USB port control, wake on LAN
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 18.5 cm
- 18.8 cm
- 5.4 cm
- 1.6 kg
- 10 °C
- 35 °C
