Fujitsu Esprimo P557 Intel Core i5-7400 4GB 1TB HDD Windows 10 Pro
Quicklinx: DLGYWS00 Mfr#: VFY:P0557P151HGB
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
£403.09 ex VAT
£483.70 inc VAT
The Fujitsu ESPRIMO P557/E85+ desktop provides high-quality computing for your daily office tasks. It supports attractive ost points and delivers the continuity, needed for daily operations. Your valuable business data is protected by the TPM controller. To meet your specific hardware needs it can be either individually configured or customized.
  • High performance
    Powerful and cost-effective micro tower.
  • System management
    The perfect answer to offload your IT administrators.
  • Long lifecycle
    Hardware continuity for long-lasting project requirements.
  • Low power consumption
    Low power consumption and low costs, without any loss in performance.
Fujitsu ESPRIMO P557/E85+ - micro tower - Core i5 7400 3 GHz - 4 GB - 1 TB - UK layout
Personal computer - micro tower
Region: United Kingdom
1 x Intel Core i5 (7th Gen) 7400 / 3 GHz (3.5 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 630 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
GigE
OS Provided
18 cm x 30.4 cm x 37.5 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
VGA, DVI, DisplayPort
HDCP compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line
Slots
1 PCIe 3.0 x16 - full-height , 2 PCIe x1 - full-height , 1 (total) / 1 (free) x M.2 Card - 2280
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort , 1 x DVI-D , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA (with adapter)
VGA extension card
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus
Power supply
Nominal Voltage
Power Provided
280 Watt
Efficiency
75% at 10% Load, 85% at 50% Load, 84% at 100% Load, 83% at 20% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Windows 10 Pro 64-bit recovery DVD
ENERGY STAR Certified
ENERGY STAR Version
6.1
18 cm
30.4 cm
37.5 cm
7 kg
10 °C
35 °C
5 - 85%
Fujitsu Esprimo P557 Intel Core i5-7400 4GB 1TB HDD Windows 10 Pro Bundle deal on Fujitsu Esprimo P557 Intel Core i5-7400 4GB 1TB HDD Windows 10 Pro
£585.60
saving £8.33
£496.12
Storage Type: HDD
Processor Model: I5-7400
Type: Personal computer
Case Style: Micro tower
Display: not included
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: Fujitsu
Price Range Ex VAT: 300 - 500
