Fujitsu Esprimo P420 Intel Core i3-4170 4GB 500GB Windows 7 Professional
Quicklinx: BP1KWS00 Mfr#: VFY:P0420P633OGB
  • Core i3
  • Microsoft Windows 7 Professional
The Fujitsu PC ESPRIMO P420 delivers high-quality computing for your office applications and projects at a very attractive price point. You can choose cost-optimized fixed configurations for immediate delivery.
  • Green IT
    Fujitsu is committed to eliminating the use of harmful and potentially harmful substances in its products and production processes in order to minimize risk to end users and to the environment. This strategy is captured in Environmental Guideline FTS03230 and forms the basis on which all Fujitsu's products are designed. Especially for Fujitsu ESPRIMO PCs this means that all used printed circuit boards are halogen free.
  • Energy efficiency
    The Fujitsu ESPRIMO P420 features proven technology regarding Intel chipset and processor and an 85% energy efficient power supply.
  • Flexibility
    Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, add-on and lifecycle management.
Fujitsu ESPRIMO P420 E85+ - micro tower - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB - UK
Personal computer - micro tower - administrator password, system password, hard drive password
Region: United Kingdom
Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
Processor Socket
LGA1150 Socket
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 4400 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
GigE
Keyboard
Software Included
Drivers & Utilities
17.5 cm x 42.5 cm x 35.3 cm
9 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Micro tower
Processor / Chipset
CPU
Clock Speed
3.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual channel memory architecture
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Storage Controller (2nd)
1 x SATA
SATA 3Gb/s
Channel Qty
1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
VGA, DVI
HDCP Compatible
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Scroll
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI 2.0
Wake on LAN (WoL), PXE support
Bays
2 (total) / 1 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 2 (total) / 2 (free) x PCIe x1 - full-height
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 2 x USB 3.0 , 1 x VGA , 1 x DVI-D , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
Administrator password, system password, hard drive password
Theft/Intrusion Protection
TUV GS, WHQL, RoHS, WEEE
Power supply
Power Provided
280 Watt
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
17.5 cm
42.5 cm
35.3 cm
9 kg
10 °C
35 °C
5 - 85%
BP1K C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
