Fujitsu Esprimo K557 23.8" AIO Intel Core i3-6100T 4GB 500GB W10P
Quicklinx: D2JVWS00 Mfr#: VFY:K5574P23HBGB
  • Core i3
  • IEEE 802.11n
The ESPRIMO K557/24 AIO desktop PC supports the budget-driven, modern workplace: streamlined workspace, reduced complexity, with no compromise in performance. This all-rounder combines powerful processors and modern interfaces in a compact, all-in-one design designed for future-oriented applications.
Fujitsu ESPRIMO K557/24 - all-in-one - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB - LED 23.8" - UK
Personal computer - all-in-one
Region: United Kingdom
Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD SuperMulti
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
Camera
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
56 cm x 9.3 cm x 36.8 cm
6.5 kg
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
All-in-one - with tilt/swivel/height adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
LED
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Response Time
14 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, WideView
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel
Resolution
Full HD
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Audio Input
Stereo microphone
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory , 1 (total) / 0 (free) x M.2 Card - 2230
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 3 x USB 2.0 (3 rear) , 1 x LAN - RJ-45 , 1 x audio line-out/headphones , 1 x audio line-in/microphone , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse
Stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus
Power supply
Power Provided
170 Watt
Efficiency
87% at 20% Load, 90% at 50% Load, 84% at 10% Load, 87% at 100% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Dimensions & Weight Details
56 cm - 9.3 cm - 36.8 cm - 6.5 kg - without stand , 56 cm - 25.8 cm - 41.1 cm - 9.7 kg - with stand
56 cm
9.3 cm
36.8 cm
6.5 kg
10 °C
35 °C
5 - 85%
