The ESPRIMO E700 E90+ is the ideal choice for your workplace. Depending on the space you have available, you can position the PC vertically or horizontally. Equipped with state-of-the-art Intel chipset and processor technology the PC provides top-performance levels to meet the requirements of your daily business applications - and remains quiet and efficient. You achieve a considerably better energy balance, protecting both the environment and your budget.
- Fujitsu ESPRIMO E700 E90+ - SFF - Core i3 2120 3.3 GHz - 2 GB - HDD 500 GB - English
- Personal computer - small form factor - administrator password, system password, hard drive password, USB port control
- Processor
- Intel Core i3 (2nd Gen) 2120 / 3.3 GHz (Dual-Core)
- Processor Socket
- LGA1155 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 2 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-10600
- Storage Controller
- SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 2000 Dynamic Video Memory Technology
- Audio Output
- 5.1 channel surround - integrated
- Networking
- GigE
- Keyboard
- English
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Software Included
- Nero Essentials S, Windows 7 Professional (32/64 bits) recovery DVD, Microsoft Office 2010 Starter, Norton Internet Security (60 days trial), Fujitsu Recovery
- 34 cm x 38.2 cm x 9.8 cm
- 10 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1155 Socket
- Chipset Type
- Intel Q65 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 2 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Unbuffered, dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Storage Controller (2nd)
- SATA 3Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Max Allocated RAM Size
- 1759 MB
- Video Interfaces
- VGA, DVI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB400
- Interface
- PS/2
- Localization & Layout
- English
Mouse
- Technology
- Optical
- Interface
- USB
- Tilt wheel
- Integrated
- Ethernet Controller
- Intel 82579V
- Data Link Protocol
- Remote Management Protocol
- DMI 2.0
- PXE support
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 0 (free) x CPU , 4 memory , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe x1 - low-profile , 1 (total) / 1 (free) x PCI - low-profile
- 1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 12 x USB 2.0 (4 front, 8 rear) , 1 x VGA (with adapter) , 1 x DisplayPort , 1 x DVI-I , 1 x serial , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet)
- Administrator password, system password, hard drive password, USB port control
- Theft/Intrusion Protection
- FCC Class B certified, CSA, WHQL, RoHS, WEEE, Nordic Swan
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- ENERGY STAR Certified
- 34 cm
- 38.2 cm
- 9.8 cm
- 10 kg
- 10 °C
- 35 °C
