Fujitsu Esprimo E420 SFF Intel Pentium G3220 4GB 250GB Windows 7 Professional
Quicklinx: 96CMWS00 Mfr#: VFY:E0420P72A1GB
  • Pentium
  • Microsoft Windows 7 Professional 64-bit Edition
The Fujitsu PC ESPRIMO E420 delivers high-quality computing for your office applications and projects at a very attractive price point. You can choose cost-optimized fixed configurations for immediate delivery. Alternatively, you can use configuration options to meet your specific hardware needs, while staying within your budget.
  • Green IT
    Fujitsu is committed to eliminating the use of harmful and potentially harmful substances in its products and production processes in order to minimize risk to end users and to the environment. Especially for Fujitsu ESPRIMO PCs this means that all used printed circuit boards are halogen free. Furthermore they are compliant with several certificates awarding environmental conscience such as ENERGY STAR and EPEAT.
  • Energy efficiency
    The Fujitsu ESPRIMO E420 features proven technology regarding Intel chipset and processor and an 85% energy efficient power supply.
  • Flexibility
    Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, software, and add-on and lifecycle management.
Fujitsu ESPRIMO E420 E85+ - SFF - Pentium G3220 3 GHz - 4 GB - HDD 250 GB - UK
Personal computer - small form factor - administrator password, system password, hard drive password
Region: United Kingdom
Intel Pentium G3220 / 3 GHz (Dual-Core)
Processor Socket
LGA1150 Socket
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
Hard Drive
HDD 250 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics Shared Video Memory (UMA)
Audio Output
5.1 channel surround - integrated
GigE
Keyboard
OS Provided
Software Included
Drivers & Utilities, Adobe Reader, Fujitsu Recovery, McAfee Multi Access (60 days trial), Workplace Protect, Windows 7 / Windows 8.1 Pro Twin-Pack recovery DVD
33 cm x 40.5 cm x 10.4 cm
9 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Intel Pentium G3220
Clock Speed
3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual channel memory architecture
Hard Drive
HDD
1 x 250 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Storage Controller (2nd)
SATA 3Gb/s
Channel Qty
1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
VGA, DVI
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
PS/2
Localization & Layout
Mouse
Optical
USB
Scroll
Integrated
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI 2.0
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 2 memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe x1 - low-profile
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x VGA , 1 x DVI-D , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet)
Administrator password, system password, hard drive password
Theft/Intrusion Protection
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
Power supply
Power Provided
280 Watt
Efficiency
86%
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
33 cm
40.5 cm
10.4 cm
9 kg
10 °C
35 °C
