Fujitsu Esprimo E400 CORE I3-2130 4GB 500GB DVDRW WIN7 P
Quicklinx: 8LJJWS00 Mfr#: VFY:E0400P73C1GB
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
Fujitsu all-round ESPRIMO PC delivers high-quality computing for your office applications and projects at a very attractive price point. The Fujitsu ESPRIMO E400 E85+ is the ideal choice for large enterprise customers who are looking for Intel Core i3 technology. This small form factor PC combines top performance and extremely attractive prices. Equipped with a power supply unit with up to 87% efficiency, thus saving energy and protecting the environment. This PC is the perfect choice for cost-driven projects.
  • Green IT
    Fujitsu is committed to eliminating the use of harmful and potentially harmful substances in its products and production processes in order to minimize risk to end users and to the environment. This strategy is captured in Environmental Guideline FTS03230 and forms the basis on which all Fujitsu's products are designed. Especially for Fujitsu ESPRIMO PCs this means that all used printed circuit boards are halogen free.
  • Energy efficiency
    The Fujitsu ESPRIMO E features the technology regarding Intel chipset and processor and optional an up to 86% energy efficient power supply.
  • Manageability
    Maximum system security and manageability are of critical importance to IT managers. With the Intel Core technology, Intel is seeking to improve these levels still further, in the deskbound and notebook sector. The Fujitsu ESPRIMO 400 series powered by Intel Core technology - simple administration made easier.
  • Flexibility
    Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, software, add-on and lifecycle management.
Fujitsu ESPRIMO E400 E85+ - DT - Core i3 2120 3.3 GHz - 4 GB - HDD 500 GB
Personal computer - desktop - administrator password, system password, hard drive password
Intel Core i3 (2nd Gen) 2120 / 3.3 GHz (Dual-Core)
Processor Socket
LGA1155 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 2000 Shared Video Memory (UMA)
Audio Output
Integrated
GigE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Adobe Reader, Windows 7 Professional (32/64 bits) recovery DVD, Microsoft Office 2010 Starter, Norton Internet Security (60 days trial), Fujitsu Recovery
33 cm x 40.5 cm x 10.4 cm
10 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Desktop
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel H61 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
Unbuffered, dual channel memory architecture
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
4
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Max Allocated RAM Size
1759 MB
Video Interfaces
VGA, DVI
HDCP Compatible
Audio Output
Integrated
High Definition Audio
Input Device
Mouse
Mouse
Optical
USB
Scroll
Integrated
Ethernet Controller
Realtek RTL8111E
Remote Management Protocol
DMI 2.0
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H
Slots
1 (total) / 0 (free) x CPU , 2 memory , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe x1 - low-profile
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 4 rear) , 1 x VGA , 1 x DVI-D , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet)
Administrator password, system password, hard drive password
Theft/Intrusion Protection
TUV GS, WHQL, RoHS, WEEE
Power supply
Power Provided
250 Watt
Efficiency
86%
Operating System / Software
OS Provided
Software
ENERGY STAR Certified
33 cm
40.5 cm
10.4 cm
10 kg
10 °C
35 °C
