The Fujitsu ESPRIMO D556/E85+ Desktop provides high-quality computing for your daily office tasks. It supports attractive price points and delivers the continuity needed for daily operations. Your valuable business data is protected by the latest TPM controller and the Erasedisk option. To meet your specific hardware needs it can be either individually configured or customized.
- Fujitsu ESPRIMO D556/E85+ - SFF - Core i5 6400 2.7 GHz - 4 GB - SSD 128 GB - UK
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Shared Video Memory (UMA)
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Home 64-bit Edition
- Software Included
- Adobe Reader, Microsoft Office (Trial), McAfee Multi Access (60 days trial), Windows 10 Home 64-bit recovery DVD
- 33.2 cm x 33.8 cm x 8.9 cm
- 8 kg
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
- Mainstream
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- PS/2
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Scroll
- Ethernet Controller
- Realtek RTL8111G
- Data Link Protocol
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe x1 - low-profile
- 1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- Efficiency
- 75% at 10% Load, 85% at 50% Load, 84% at 100% Load, 83% at 20% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- 33.2 cm
- 33.8 cm
- 8.9 cm
- 8 kg
- 10 °C
- 35 °C
- 5 - 85%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.89 |
