Fujitsu Esprimo D556 Intel Core i5-6400 4GB 128GB SSD Windows 10 Home
Quicklinx: BZPWWS00 Mfr#: VFY:D0556P85SCGB
  • Core i5
The Fujitsu ESPRIMO D556/E85+ Desktop provides high-quality computing for your daily office tasks. It supports attractive price points and delivers the continuity needed for daily operations. Your valuable business data is protected by the latest TPM controller and the Erasedisk option. To meet your specific hardware needs it can be either individually configured or customized.
Fujitsu ESPRIMO D556/E85+ - SFF - Core i5 6400 2.7 GHz - 4 GB - SSD 128 GB - UK
Personal computer - small form factor
Region: United Kingdom
Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
GigE
Keyboard
OS Provided
Windows 10 Home 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (Trial), McAfee Multi Access (60 days trial), Windows 10 Home 64-bit recovery DVD
33.2 cm x 33.8 cm x 8.9 cm
8 kg
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 128 GB
Interface Type
SATA 6Gb/s
Mainstream
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
PS/2
Localization & Layout
Mouse
Optical
USB
Scroll
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe x1 - low-profile
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
Power supply
Power Provided
280 Watt
Efficiency
75% at 10% Load, 85% at 50% Load, 84% at 100% Load, 83% at 20% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
33.2 cm
33.8 cm
8.9 cm
8 kg
10 °C
35 °C
5 - 85%
BZPW C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
