Fujitsu Esprimo D538 E85 Core i5-84008GB 256GB Windows 10 Pro
Quicklinx: DYZVWS00 Mfr#: VFY:D0538P251SGB
  • Core i5
The Fujitsu ESPRIMO family delivers outstanding reliability and durability. It combines availability with energy-saving performance.
  • Superior power efficiency
    Light-load optimized power supply offers low energy consumption in standard operation mode.
  • Load and customizing
    Efficient configuration and individualization of devices providing high cost savings despite complex IT infrastructures.
  • Better manageability
    Significant TCO reduction via a comprehensive offer of system management functions.
  • Security and flexibility
    Get sophisticated security tools and scalable configuration with the ESPRIMO family, depending on business requirements.
Fujitsu ESPRIMO D538/E85+ - SFF - Core i5 8400 2.8 GHz - 8 GB - SSD 256 GB - UK
Personal computer - small form factor
Region: United Kingdom
Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
Processor Socket
LGA1151 Socket
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - 2.5"
Optical Storage
DVD SuperMulti
Graphics Controller
Intel UHD Graphics 630 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
GigE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Fujitsu DeskUpdate, Windows 10 64-bit recovery DVD
31.3 cm x 28.6 cm x 8.9 cm
5 kg
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H310
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - 2.5"
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 PCIe 3.0 x16 - low-profile , 1 PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x M.2 Card - 2280
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x VGA (with adapter)
VGA extension card
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cTUVus, CEL
Power supply
Power Provided
210 Watt
Efficiency
80% at 10% Load (230 VAC), 85% at 20% Load (230 VAC), 88% at 50% Load (230 VAC), 87% at 100% Load (230 VAC), 79% at 10% Load (115 VAC), 84% at 20% Load (115 VAC), 87% at 50% Load (115 VAC), 84% at 100% Load (115 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
31.3 cm
28.6 cm
8.9 cm
5 kg
10 °C
35 °C
5 - 85%
