The ergonomic KBPC E keyboard from Fujitsu Technology Solutions sets new ergonomic standards at the workplace. The knowledge gleaned from exhaustive ergonomic studies has facilitated optimum compliance with individual physiological and anatomical requirements and user preferences.
The KBPC E promotes the natural positioning of the user's arms and hands, for fatigue-free use. The alphanumeric keypad splits into two halves, angled at up to 30° to each other, plus the lateral pitch of up to 16°. The keyboard allows a front-to-back inclination of either 6° or 12°. This allows the hands to fall into a natural posture, reducing strain on the hand-arm-shoulder system. The matching wrist pad provides optimum support; even where the lateral angle employed is great.
Upgrading from standard keyboards to the KBPC E is simplicity itself. For one thing the MF-compatible key layout has been retained, whilst the angle adjustment features three levels. A compact keyboard can thus be turned, step-by step, into a keyboard ergonomically optimized to suit individual requirements.
- Fujitsu KBPC E - keyboard - UK Input Device
- Keyboard - ergonomic
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 89
- Palm rest
- 38.3 cm x 25.6 cm x 4.2 cm
- 1.3 kg
- Designed For
- Celsius J550/2, J580, R940 POWER; CELSIUS Mobile H970; ESPRIMO C910-L, D538/E94+, D556/, D556/2/, D556/PX, D738/E94+, D757/, D757/E94+, D957/, D957/E94+, D958/, D958/E94+, P556, P556/2/, P957/power, Q956/MRE
- Interface
- USB
- Keys Qty
- 89
- UK
- Region
- United Kingdom
- Keyboard Technology
- Membrane
- Palm rest
- 38.3 cm
- 25.6 cm
- 4.2 cm
- 1.3 kg
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- ISO 9241-4, EN 61000-3-2, GS, PCT, UL 1950, ZH1 618, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B
- OS Required
- Microsoft Windows 2000 / XP
- 5 °C
- 40 °C
- Designed For
- Fujitsu Celsius J550/2, J580, R940 POWER , Fujitsu CELSIUS Mobile H970 , Fujitsu ESPRIMO C910-L, D538/E94+, D556/2/E85+, D556/2/E90+, D556/E85+, D556/PX, D738/E94+, D757/E85+, D757/E90+, D757/E94+, D957/E85+, D957/E90+, D957/E94+, D958/E85+, D958/E94+, P556 E85+, P556/2/E85+, P957/power, Q956/MRE
