The E22-8 TS Pro is an all-round business monitor that has IPS technology, enabling you to see sharp pictures consistently from any perspective.
- Fujitsu E22-8 TS Pro - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class D
- Energy Consumption per Year
- 21 kWh
- Power Consumption (On mode)
- 11.6 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.05 cm x 21.2 cm x 34.35 cm
- 2.98 kg
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, VCCI, BSMI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, S Mark, E-Standby, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class D
- 21 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- HDCP, ECO button, High Frame Rate Control (Hi-FRC), Low Blue Light Mode
- Black
- 50.05 cm x 21.2 cm x 34.35 cm - with stand
- 2.98 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D (HDCP) , DisplayPort , Audio line-out , Audio line-in
Mechanical
- Height, tilt
- Tilt Angle
- -5.5/+22
- Height Adjustment
- 63 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m
- Localisation
- United Kingdom
- Input Voltage
- 11.6 W
- Power Consumption SDR (On mode)
- 11.6 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.16 Watt
- Power Consumption Sleep
- 0.12 Watt
- Included Software
- Display View IT Suite
- Dimensions & Weight Details
- Without stand - width: 50.05 cm - depth: 5.57 cm - height: 29.8 cm - weight: 2.68 kg , With stand - width: 50.05 cm - depth: 21.2 cm - height: 34.35 cm - weight: 2.98 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
