Has your desktop reached the limit in terms of performance, scalability and expandability? Than the FUJITSU CELSIUS W550 desktop workstation is your ideal choice, especially for video editing, MCAD/electrical CAD or Architecture, Engineering and Construction applications. Enjoy best-in-class low noise emissions of only 18 dB(A) for a quiet and efficient working environment.
- Fujitsu Celsius W550 - micro tower - Core i5 6600 3.3 GHz - vPro - 8 GB - Hybrid Drive 500 GB - UK
- Workstation - micro tower
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Core i5 (6th Gen) 6600 / 3.3 GHz (, up to 3.9 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- Hybrid Drive 500 GB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 24 in 1
- Graphics Controller
- NVIDIA Quadro K420 / Intel HD Graphics 530 Shared Video Memory (UMA)
- Video Memory
- 1 GB
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
- Software Included
- Drivers & Utilities, Adobe Reader, Microsoft Office (Trial), Fujitsu Recovery, DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect
- 17.5 cm x 41.9 cm x 39.5 cm
- 11 kg
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6600
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- Hybrid Drive
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
- 24 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 1 GB
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Keyboard Name
- Fujitsu KB900
- Localization & Layout
- UK
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x internal 2.5" x 1/8H , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25" x 1/2H
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 2 (total) / 2 (free) x PCIe 3.0 x1 - full-height , 1 PCIe 3.0 x16 - full-height (x4 mode) , 1 PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x M.2 Card
- 1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 7 x USB 3.0 (2 front, 4 rear, 1 internal) , 3 x DisplayPort , 1 x DVI-D , 1 x serial , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DVI-I (dual link)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
- Power supply
- Voltage Required
- Power Provided
- 300 Watt
- Efficiency
- 90% at 100% Load, 88% at 20% Load, 92% at 50% Load, 84% at 10% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- 17.5 cm
- 41.9 cm
- 39.5 cm
- 11 kg
- 10 °C
- 35 °C
- 5 - 85%
