Fujitsu Celsius W550 E3-1240v5 8GB 1TB Windows 7 Professional
Quicklinx: BZVKWS00 Mfr#: VFY:W5500W781BGB
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Has your desktop reached the limit in terms of performance, scalability and expandability? Than the Fujitsu Celsius W550 desktop workstation is your ideal choice, especially for video editing, MCAD/electrical CAD or architecture, engineering and construction applications. Enjoy low noise emissions for a quiet and efficient working environment.
  • Abundant performance at an affordable price
    Enjoy impressive professional graphics and storage capacity at an affordable price. Boost your storage performance with super-fast PCIe SSDs to provide a quick loading of core applications and reliable high-endurance and business critical drives designed for long-term operation.
  • Whisper quiet design
    Fujitsu's desktop workstations are designed, engineered and manufactured in the heart of Europe. Enjoy a silent workplace environment thanks to a low noise emission.
Fujitsu Celsius W550 - micro tower - Xeon E3-1240V5 3.5 GHz - 8 GB - HDD 1 TB
Workstation - micro tower
Region: United Kingdom
1 x Intel Xeon E3-1240V5 / 3.5 GHz (3.9 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
24 in 1
Graphics Controller
NVIDIA Quadro K620
Video Memory
2 GB
Audio Output
5.1 channel surround
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
17.5 cm x 41.9 cm x 39.5 cm
11 kg
Limited warranty - 3 years - on-site
Workstation
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
24 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
NVIDIA Quadro K620
Video Memory
2 GB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB900
USB
Mouse
Optical
USB
Tilt wheel
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 2.5" x 1/8H , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25" x 1/2H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 2 (total) / 2 (free) x PCIe 3.0 x1 - full-height , 1 PCIe 3.0 x16 - full-height (x4 mode) , 1 PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x M.2 Card
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 7 x USB 3.0 (2 front, 4 rear, 1 internal) , 1 x DisplayPort , 1 x serial , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DVI-I (dual link)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Power Provided
300 Watt
Efficiency
90% at 100% Load, 88% at 20% Load, 92% at 50% Load, 84% at 10% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Microsoft Office (Trial)
17.5 cm
41.9 cm
39.5 cm
11 kg
10 °C
35 °C
5 - 85%
