Fujitsu Celsius W550 Core i5-6500 8GB 500GB Windows 10 Pro
Quicklinx: CS3NWS00 Mfr#: VFY:W5500W25BGGB
  • Core i5
Has your desktop reached the limit in terms of performance, scalability and expandability? Than the FUJITSU CELSIUS W550 desktop workstation is your ideal choice, especially for video editing, MCAD/electrical CAD or Architecture, Engineering and Construction applications. Enjoy best-in-class low noise emissions of only 18 dB(A) for a quiet and efficient working environment.
Fujitsu Celsius W550 - micro tower Core i5 6500 3.2 GHz - 8 GB - HDD 500 GB - UK
Workstation - micro tower
Region: United Kingdom
1 x Intel Core i5 (6th Gen) 6500 / 3.2 GHz (up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe x16 - AMD FirePro W2100 / Intel HD Graphics 530 Shared Video Memory (UMA)
Video Memory
2 GB
Audio Output
5.1 channel surround
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect
17.5 cm x 41.9 cm x 39.5 cm
11 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Workstation
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe x16
Graphics Processor
Video Memory
2 GB
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
PS/2
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 2.5" , 2 (total) / 1 (free) x internal 3.5" , 2 (total) / 2 (free) x external 3.5" , 2 (total) / 1 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 2 (free) x PCIe 3.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x M.2 Card
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 7 x USB 3.0 (2 front, 4 rear, 1 internal) , 4 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Power Provided
300 watt
Efficiency
90% at 100% Load, 88% at 20% Load, 92% at 50% Load, 84% at 10% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
17.5 cm
41.9 cm
39.5 cm
11 kg
10 °C
35 °C
5 - 85%
