The CELSIUS M740 workstation has been optimized to combat today's professional and technical challenges. It can be individually configured, helping you to enhance your productivity. To round things off, a near-silent noise emission allows you to work comfortably in the most quiet of working environments.
Workstation application field
The Fujitsu CELSIUS M740 is optimized for most demanding, single-processor applications like computer aided engineering, architecture, post-processing and financial analysis. -
Quiet operation
Fujitsu workstations offer low noise emissions for a pleasant working environment. This is achieved through an optimized thermal management system, which makes use of air tunnels to provide efficient airflow within the system. -
Easy upgrades
Thanks to intelligent design and comfortable cold plug access at front, rapid change and upgrade of hard disk drives is ensured.
- Fujitsu Celsius M740 - tower - Xeon E5-1650V3 3.5 GHz - vPro - 32 GB - SSD 256 GB
- Workstation - tower - administrator password, system password, hard drive password, USB port control, Fujitsu EraseDisk, supports AHCI mode
- Platform Technology
- Intel vPro Platform
- Processor
- 1 x Intel Xeon E5-1650V3 / 3.5 GHz (, up to 3.8 GHz, (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 32 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Card Reader
- 24 in 1
- Graphics Controller
- PCIe x16 - NVIDIA Quadro K4200
- Video Memory
- 4 GB
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
- Software Included
- Drivers & Utilities, DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect, Microsoft Office 2013 (30 days trial)
- 18.6 cm x 48.1 cm x 43 cm
- 18 kg
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
- CPU
- Intel Xeon E5-1650V3
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 32 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 6 (empty)
- Registered
- Configuration Features
- 2 x 16 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 24 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Plug-in card
- Interface Type
- PCIe x16
- Graphics Processor
- Video Memory
- 4 GB
- Video Interfaces
- DVI, DisplayPort
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB900
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Tilt wheel
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 8 (total) / 7 (free) x internal 2.5" x 1/8H , 4 (total) / 3 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H
- Slots
- 1 (total) / 0 (free) x CPU , 8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 2.0 x8 - full-height (x1 mode)
- 2 x audio line-in (1 in front) , 2 x audio line-out (1 in front) , 9 x USB 2.0 (2 front, 4 rear, 3 internal) , 4 x USB 3.0 (2 in front) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DVI-I (dual link) , 2 x DisplayPort
- Administrator password, system password, hard drive password, USB port control, Fujitsu EraseDisk, supports AHCI mode
- Theft/Intrusion Protection
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 600 Watt
Operating System / Software
- OS Provided
- Software
- 18.6 cm
- 48.1 cm
- 43 cm
- 18 kg
- 10 °C
- 35 °C
- 5 - 85%
