Fujitsu Bluetooth Mouse V470
Quicklinx: 9QJLWS00 Mfr#: LTC:M-RCQ142
As the name would suggest, the Bluetooth Mouse V470 is ideal for notebooks with integrated Bluetooth receiver.
The Bluetooth Mouse V470 is a laser mouse with 1.000 dpi and delivers smoother cursor control on nearly any surface. Scroll horizontally or vertically and take it wherever you go. Use the delivered travel pouch to protect it from dirt, scratches and to keep it dry. The special design and the midi size offer a comfortable long-time usage for right and left-handed users.
Fujitsu V470 - mouse - Bluetooth
Mouse
Wireless - Bluetooth
Orientation
Right and left-handed
5.7 cm x 10 cm x 3.9 cm
62 g
Movement Detection Technology
Laser
Movement Resolution
1000 dpi
Tilt Wheel technology, scrolling wheel (4-way)
2 x AAA type
Microsoft Windows Vista / XP
CELSIUS Mobile H250; ESPRIMO Q1500, Q1510, Q5010, Q5020, Q5030, Q900, Q9000; ESPRIMO Mobile D9500, D9510, M9400, M9410, U9200, U9210, V5505, V5515, V5545, X9525; LIFEBOOK E8420, P1620, P3110, P770, P8010, P8020, Q2010, S6420, S7110, S7210, S7220, T1010, T4310, T4410, T5010; Stylistic Q550, ST6012
Mouse
Orientation
5.7 cm
10 cm
3.9 cm
62 g
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Laser
Movement Resolution
1000 dpi
Carrying pouch
EN55022 Class B, EN 61000-4-2, EN 61000-4-3, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC CFR47 Part 15 C, EN 300 328, EN 301 489-1, EN 301 489-3
AAA type
Installed Qty
2
Software Included
Drivers & Utilities
Fujitsu CELSIUS Mobile H250 , Fujitsu ESPRIMO Q1500, Q1510, Q5010, Q5020, Q5030 E-Star 4.0, Q900, Q9000 , Fujitsu ESPRIMO Mobile D9500, D9510, M9400, M9410, U9200, U9210, V5505, V5515, V5545, X9525 , Fujitsu LIFEBOOK C1320, C1410, E8010, E8010D, E8010S, E8020, E8020 Mainstream, E8020 Supreme, E8110, E8210, E8310, E8410, E8420, E8420 proGREEN, P1610, P1620, P3110, P7120, P7230, P770, P8010, P8010 Crimson Red, P8020, Q2010, Q2010 Executive, Q2010 Superior, Q2010 Supreme, S2110, S6410, S6420, S7010, S7010 Basic, S7010 Supreme, S7010D, S7010D Basic, S7010D Supreme, S7020, S7020 Basic, S7020 Supreme, S7020 Value, S7110, S7110 Fingerprint, S7110 Supreme, S7110 Value, S7110 Value FP, S7210, S7210 CAM, S7210 FP, S7220, T1010, T4210, T4215, T4220, T4310, T4410, T5010 , Fujitsu Stylistic Q550, ST5010, ST5010D, ST5011, ST5011D, ST5020, ST5021, ST5022, ST5031, ST5032, ST5111, ST5112, ST6012
