The B27T-7 Pro is made for intensive office work. With visual and mechanical ergonomics this display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
- Fujitsu B27T-7 Pro - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 18 W
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Marble grey
- 64.4 cm x 22.7 cm x 40.5 cm
- 8.9 kg
- Localisation
- United Kingdom
- FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
- Display Type
- Energy Class
- Class A+
- 27 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- HDCP, ECO button, DisplayView, High Frame Rate Control (Hi-FRC)
- Marble grey
- 64.4 cm x 22.7 cm x 40.5 cm - with stand
- 8.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream (Type A) , USB upstream (Type B)
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 24x7 continuous operation
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
- MTBF
- 70,000 hour(s)
- Localisation
- United Kingdom
- Input Voltage
- 18 W
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.2 Watt
- Dimensions & Weight Details
- With stand - width: 64.4 cm - depth: 22.7 cm - height: 40.5 cm - weight: 8.9 kg , Without stand - width: 64.4 cm - depth: 7.2 cm - height: 38.3 cm - weight: 5.9 kg
- 5 °C
- 35 °C
