Fujitsu B24W-7 24" 1920x1200 5ms VGA DVI DisplayPort LED IPS Monitor
Quicklinx: DLJ8WS00 Mfr#: BDL:K1497V141-UK
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, DisplayPort, VGA (HD-15)
£254.16 ex VAT
£304.99 inc VAT
The FUJITSU B24W-7 LED display with excellent ergonomics makes intensive office work extremely comfortable. This highly reliable display offers superb usability and power-saving features to help reduce your labor as well as energy costs. With wide viewing angle technology, flexible connectivity, and easy manageability, the FUJITSU B24W-7 LED display can help you improve productivity.
  • Exceeding ergonomics
    The human-centric design is gentle on the eyes and healthy for the posture: sophisticated stand with height adjustment including tilt, swivel and optimized viewing ergonomics with wide viewing angle technology
  • Eco system
    Eco mode is a preset brightness adjust that fits for typical office environment delivering optimum brightness for most office applications. Eco button comfortably switches between Eco mode and best picture performance. Eco LED indicator makes energy saving visible.
  • LED backlight technology
    Benefit from ultra-high contrast and allover illumination for less eye strain, economical power consumption and environment-conscious, mercury-free panels.
Fujitsu B24W-7 LED - Business Line - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
18.5 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Marble grey
55.9 cm x 20.4 cm x 38.4 cm
6.9 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, VCCI, cUL, EN 60950, GS, SASO, TUV S, DDC/CI, RoHS, ISO 9241-307, WEEE, S Mark, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C
3-year warranty
Display Type
Energy Class
Class E
28 kWh
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, ECO button, DisplayView, ultra wide viewing angle, 24/7 operating mode
Marble grey
55.9 cm x 20.4 cm x 38.4 cm - with stand
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Audio line-out , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Security Slot Type
Kensington security slot
Input Voltage
18.5 W
18.5 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.22 Watt
Power Consumption Sleep
0.15 Watt
Included Software
Display View IT Suite
Dimensions & Weight Details
With stand - width: 55.9 cm - depth: 20.4 cm - height: 38.4 cm - weight: 6.9 kg , Without stand - width: 55.9 cm - depth: 6.4 cm - height: 36.6 cm - weight: 4.2 kg
Shipping Weight
8.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: Fujitsu
