The FUJITSU display B24-8 TE Pro is made for intensive office work. With visual and mechanical ergonomics this display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
 - Fujitsu B24-8 TE Pro - Business Line - LED monitor - Full HD (1080p) - 23.8"
 - LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/347769
- Energy Class
 - Class D
- Energy Consumption per Year
 - 28 kWh
- Power Consumption (On mode)
 - 13.7 W
 - USB 2.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 20000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey)
- Colour Support
 - 16.7 million colours
- Input Connectors
 - DVI-D, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Marble grey
 - 55.3 cm x 22.94 cm x 34.7 cm
 - 5.6 kg
- Localisation
 - United Kingdom
- Environmental Standards
 - ENERGY STAR Qualified
 - FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, TUV S, CCC, RoHS, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO9241-307
 - 3-year warranty
- Display Type
- Energy Class
 - Class D
 - 28 kWh
- Diagonal Size
 - 23.8"
- Built-in Devices
 - USB 2.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
 - 56 - 76 Hz
- Horizontal Refresh Rate
 - 30 - 82 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
- Colour Temperature
 - 5000K, 6500K, 7500K
- OSD Languages
 - Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
 - sRGB colour management, HDCP, ECO button, DisplayView, High Frame Rate Control (Hi-FRC), Low Blue Light Mode, built-in speakers
 - Marble grey
 - 55.3 cm x 22.94 cm x 34.7 cm - with stand
 - 5.6 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 2 Watt
 - DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-out
Mechanical
- Tilt Angle
 - -5/+35
- Swivel Angle
 - 340
- Rotation Angle
 - 90
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), 24x7 continuous operation
- Included Accessories
 - Stand
- Cables Included
 - 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
- MTBF
 - 70,000 hour(s)
- Localisation
 - United Kingdom
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 13.7 W
- Power Consumption SDR (On mode)
 - 13.7 kWh/1000h
- Power Consumption (Typical)
 - 23 Watt
- Power Consumption Stand by
 - 0.17 Watt
- Power Consumption Sleep
 - 0.16 Watt
- Included Software
 - Drivers & Utilities
- Dimensions & Weight Details
 - With stand - width: 55.3 cm - depth: 22.94 cm - height: 34.7 cm - weight: 5.6 kg , Without stand - width: 55.3 cm - depth: 6.35 cm - height: 33.02 cm - weight: 3.5 kg
Sustainability Information
- ENERGY STAR Certified
 - Limited warranty - 3 years - pick-up and return
 - 5 °C
 - 35 °C
