Fujitsu B23T-7 23" 1920x1080 5ms VGA DVI DisplayPort LED Monitor
Quicklinx: CZ9ZWS00 Mfr#: BDL:K1496V140-UK
The FUJITSU B23T-7 LED display with excellent ergonomics makes intensive office work extremely comfortable. This highly reliable display offers superb usability and power-saving features to help reduce your labor as well as energy costs. With wide viewing angle technology, flexible connectivity, and easy manageability, the FUJITSU B23T-7 LED Display can help you improve productivity.
  • Exceeding ergonomics
    The human-centric design is gentle on the eyes and healthy for the posture: sophisticated stand with height adjustment including tilt, swivel and optimized viewing ergonomics with wide viewing angle technology.
  • Eco system
    Eco mode is a preset brightness adjust that fits for typical office environment delivering optimum brightness for most office applications. Eco button comfortably switches between Eco mode and best picture performance. Eco LED indicator makes energy saving visible.
  • LED backlight technology
    Benefit from ultra-high contrast and allover illumination for less eye strain, economical power consumption and environment-conscious, mercury-free panels.
Fujitsu B23T-7 LED - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Marble grey
55 cm x 20.4 cm x 35 cm
6.2 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, VCCI, cUL, EN 60950, GS, SASO, TUV S, DDC/CI, RoHS, WEEE, EN 60601-1-2, S Mark, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, ISO9241-307
3-year warranty
Display Type
Energy Class
Class A+
25 kWh
Diagonal Size
23"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, phase, clock, black level
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, ECO button, DisplayView, 72% NTSC colour gamut
Marble grey
55 cm x 20.4 cm x 35 cm - with stand
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
DisplayPort , DVI (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Input Voltage
17 W
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.16 Watt
Power Consumption Sleep
0.1 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 55 cm - depth: 20.4 cm - height: 35 cm - weight: 6.2 kg , Without stand - width: 55 cm - depth: 6.1 cm - height: 33.1 cm - weight: 3.6 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
