Fujitsu B22W-7 22" 1680x1050 5ms VGA DVI DisplayPort LED Monitor
Quicklinx: DLJ6WS00 Mfr#: BDL:K1472V141-UK
The Display B22W-7 LED offers best ergonomics and usability for intensive office use with a 4-in-1 stand.
Customers with focus on ergonomics prefer the flexibility of a stand that is totally flexible for individual adjustments. Best-in-class height-adjust, stunning swivel, tilt and rotation to portrait guarantee a healthy, fatigue-free posture during long usage sessions.
  • Exceeding ergonomics
  • Eco system
    Eco mode is a preset brightness adjust that fits for typical office environment delivering optimum brightness for most office applications. Eco button comfortably switches between Eco mode and best picture performance. Eco LED indicator makes energy saving visible.
  • LED backlight technology
    Benefit from ultra-high contrast and allover illumination for less eye strain, economical power consumption and environment-conscious, mercury-free panels.
Fujitsu B22W-7 LED - Business Line - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
15 W
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Marble grey
51.4 cm x 19.9 cm x 36.7 cm
6 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, C-Tick, cUL, EN 60950, SASO, TUV S, CCC, DDC/CI, RoHS, WEEE, KC, Directive 2004/108/EEC, EAC, RCM, ISO 9241-307 Class 1
3-year warranty
Display Type
Energy Class
Class A+
22 kWh
Diagonal Size
22"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, ECO button, High Frame Rate Control (Hi-FRC), 24/7 operating mode
Marble grey
51.4 cm x 19.9 cm x 36.7 cm - with stand
6 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , DisplayPort , Audio line-out , Audio line-in , 4 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Input Voltage
15 W
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.19 Watt
Power Consumption Sleep
0.16 Watt
Included Software
Display View IT Suite
Dimensions & Weight Details
With stand - width: 51.4 cm - depth: 19.9 cm - height: 36.7 cm - weight: 6 kg , Without stand - width: 51.4 cm - depth: 6.5 cm - height: 34.6 cm - weight: 3.4 kg
Shipping Weight
7.5 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
