The B24-8 TS Pro is made for intensive office work. With visual and mechanical ergonomics this stylish display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
- Fujitsu B22-8 TS Pro - Business Line - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class D
- Energy Consumption per Year
- 21 kWh
- Power Consumption (On mode)
- 11.6 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 10 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.05 cm x 21.27 cm x 32.255 cm
- 4.63 kg
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, VCCI, BSMI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, S Mark, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
- 3-year warranty
- Display Type
- Energy Class
- Class D
- 21 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode, Overdrive technology, ECO button, DisplayView, WideView, High Frame Rate Control (Hi-FRC), Low Blue Light Mode, Flicker Free technology, 24/7 operating mode
- Black
- 50.05 cm x 21.27 cm x 32.255 cm - with stand
- 4.63 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- VGA ¦ DVI-D (HDCP) ¦ Audio line-out ¦ Audio line-in ¦ 2 x USB 2.0 downstream ¦ USB 2.0 upstream ¦ DisplayPort
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m ¦ 1 x DVI cable - 1.8 m ¦ 1 x USB cable - USB Type A to B - 1.8 m ¦ 1 x audio cable - 1.8 m
- Localisation
- United Kingdom
- Input Voltage
- 11.6 W
- Power Consumption SDR (On mode)
- 11.6 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.16 Watt
- Power Consumption Sleep
- 0.12 Watt
- Included Software
- Display View IT Suite
- Dimensions & Weight Details
- With stand - width: 50.05 cm - depth: 21.27 cm - height: 32.255 cm - weight: 4.63 kg ¦ Without stand - width: 50.05 cm - depth: 5.575 cm - height: 29.828 cm - weight: 2.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
