Fujitsu B22-8 TS 21.5" 1920x1080 5ms VGA DVI DP LED IPS Monitor
Quicklinx: DLJ5WS00 Mfr#: BDL:K1602V160-UK
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DVI, DisplayPort
£113.93 ex VAT
£136.71 inc VAT
The B24-8 TS Pro is made for intensive office work. With visual and mechanical ergonomics this stylish display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Fujitsu B22-8 TS Pro - Business Line - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/356808
Energy Class
Class D
Energy Consumption per Year
21 kWh
Power Consumption (On mode)
11.6 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 10 ms (typical)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
50.05 cm x 21.27 cm x 32.255 cm
4.63 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, BSMI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, S Mark, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
3-year warranty
Display Type
Energy Class
Class D
21 kWh
Diagonal Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Overdrive technology, ECO button, DisplayView, WideView, High Frame Rate Control (Hi-FRC), Low Blue Light Mode, Flicker Free technology, 24/7 operating mode
50.05 cm x 21.27 cm x 32.255 cm - with stand
4.63 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-out , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m , 1 x audio cable - 1.8 m
United Kingdom
Input Voltage
11.6 W
11.6 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.16 Watt
Power Consumption Sleep
0.12 Watt
Included Software
Display View IT Suite
Dimensions & Weight Details
With stand - width: 50.05 cm - depth: 21.27 cm - height: 32.255 cm - weight: 4.63 kg , Without stand - width: 50.05 cm - depth: 5.575 cm - height: 29.828 cm - weight: 2.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
10 - 85% (non-condensing)
Response Time: 5ms
Interfaces: DVI
Interfaces: DisplayPort
Brand: Fujitsu
