Fujitsu 2D Barcode Module for PaperStream
Quicklinx: CR9CWS00 Mfr#: PA43404-A433
£320.47 ex VAT
£384.56 inc VAT
This option enables the scanner to recognize 2D Barcode. (PDF417, QR code, Data Matrix).
  • Simple UI
    PaperStream Capture is simple and easy to use. Users can configure scanning profiles or templates with an intuitive wizard, and start scanning with just a single click of an icon. Visually display files as thumbnails, organize thumbnails according to scanning batches, and quickly switch between display settings.
  • Customizable and predefined profiles
    Predefined templates and extraction options reduce time spent on administrative operations. Administrators can also lock profiles to maintain consistent scanning.
  • Various scanning options
    Users can scan in whatever way that suits personal preferences without any hassle. Easy batch scanning with predefined templates is possible with default settings, while quick non-profile scanning can be done with Simple Scan. Users can also make one-off scans with Ad Hoc Scan, enabling users to make quick scans with temporary changes in existing profiles.
  • Document sorting and indexing
    Documents can be separated according to blank pages, page numbers, patch codes, Zonal OCR, and barcodes. Assignment of shortcut keys for manual separation during scanning is also possible for full control of sorting processes. While such sorting includes any combination of multi-index value or barcode and Zonal OCR, data from such sources can be extracted for data retention and future use.
  • Automatic image quality check
    Avoid overlooking scanning errors with Automatic Image Quality Check. Instantly recognize any multi-feed and scanning error with easily recognizable color marking: multifeeds boxed in red, blank documents in black, and missing edges in yellow.
PaperStream Capture 2D Barcode Module - licence - 1 licence
Licence
Category
Utilities - scan jobs & scanner management
Licence Qty
1 licence
Platform
Windows
Fi-5530C2, 5950, 6110, 6130Z, 6140Z, 6230Z, 6230ZLA, 6240Z, 6400, 65F, 6670, 6670A, 6750S, 6770, 6770A, 6800, 7030, 7140, 7160, 7180, 7240, 7260, 7280, 7460, 7480, 7600, 7700, 7700S, 800R, 8150, 8170, 8250, 8270; Network Scanner N7100A
Category
Licence
Platform
Windows
Licencing
Licence Qty
1 licence
Fujitsu fi-5530C2, 5950, 6110, 6130Z, 6140Z, 6230Z, 6230ZLA, 6240Z, 6400, 65F, 6670, 6670A, 6750S, 6770, 6770A, 6800, 7030, 7140, 7160, 7180, 7240, 7260, 7280, 7460, 7480, 7600, 7700, 7700S, 800R, 8150, 8170, 8250, 8270 , Fujitsu Network Scanner N7100A
Type: Scanner barcode decoder
Brand: Fujitsu
