Direct the LED light on the side of the printer at your Smartphone and move the printer around in the air to write or draw on your image. Let your creativity flow!
The free downloadable INSTAX MINI LINK app to easily print multiple images right from your Smartphone in short time! You can even print your favorite still from a video!
Press the upper button on the printer. Once the printer vibrates you can start drawing. Move the printer around in the air and let your creativity flow! You can also draw on your image with your finger in the app. For even more fun, take a video of your drawing in the air, share it as a QR code on your photo and print!
Draw in the air with instaxAiR
Direct the LED light on the side of the printer at your Smartphone and move the printer around in the air to write or draw on your image. Let your creativity flow! -
Easy and continuous high-speed printing
The free downloadable INSTAX MINI LINK app to easily print multiple images right from your Smartphone in short time! You can even print your favorite still from a video! -
Draw in the air, see your drawing appear on your image and then print
Press the upper button on the printer. Once the printer vibrates you can start drawing. Move the printer around in the air and let your creativity flow! You can also draw on your image with your finger in the app. For even more fun, take a video of your drawing in the air, share it as a QR code on your photo and print! -
Match test
Test your compatibility with friends and watch the results appear on your print! -
Sketch, edit and print
Import and add your sketches or text to your photo, then print! -
Frame print
Choose fun frame designs to add to your photo. -
Collage print
Choose from various collage styles to combine your favorite photos together! -
Enhanced quality photos
Choose the "INSTAX-Rich Mode" for rich colors and "INSTAX-Natural Mode" to print the natural colors of the image
- Fujifilm instax mini Link 2 - printer - colour - LED
- Printer Type
- Compact photo printer - LED - colour
- Form Factor
- Portable
- 210 g
- Max Media Size
- 86 x 54 mm
- Max Media Size (Custom)
- 86 mm x 54 mm
- Max Resolution (Colour)
- 318 dpi
- Interface
- Bluetooth 4.2 LE
- Media Type
- Film
- Battery
- Lithium Ion
- Enclosure Colour
- Space blue
- 9.19 cm x 3.64 cm x 12.48 cm
- Printer Type
- Enclosure Colour
- Space blue
Printer
- Connectivity Technology
- Wireless
- Interface
- Bluetooth 4.2 LE
- 318 dpi
Media Handling
- Media Type
- Film
- Max Media Size
- 86 x 54 mm
- 86 mm x 54 mm
- Media Sizes
- 86 x 54 mm
- Max Printing Width
- 62 mm
- Max Printing Length
- 46 mm
- Cables Included
- 1 x micro-USB charge cable - 30 cm
- Power Device
- Battery - internal
- 3 Watt
- Lithium Ion
- Run Time (Up To)
- 100 pages
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- 9.19 cm
- 3.64 cm
- 12.48 cm
- 210 g
