The instax SQUARE SQ20 allows you to creatively showcase the beauty of moving subjects. Whether you're capturing that exciting moment or a thrilling adventure the instax SQ20 allows you to enjoy photography and instant prints like never before.
Frame grab
Shoot a video up to 15 seconds long, use the dial on the back of the camera to select the frame that captures the best moment and print your photo. Capturing a moving subject has never been so easy. -
Timeshift collage
Four images can be taken with a time difference at one time. Press the shutter button to shoot when four images appear on the monitor. The time difference between frames can be adjusted within 0.2 to 2.0 seconds. -
Selfie mirror
A mirror is included next to the lens to ensure the perfect selfie every time. -
Digital zoom
The SQ20 includes a digital zoom function. The digital zoom allows you to zoom up to 4x to adjust your view.
- Fujifilm Instax SQUARE SQ20 - digital camera
- Product Type
- Digital camera - compact with instant photo printer
- Memory Card Slot
- microSD card
- Sensor Resolution
- 3.7 Megapixel
- Max Video Resolution
- 800 x 800
- Lens System
- F/2.4
- Focus Adjustment
- Automatic
- Min Focus Distance
- 10 cm
- Digital Zoom
- 4x
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.7"
- Supported Battery
- Li-ion rechargeable battery (included)
- Interface
- USB 2.0
- Beige
- 11.9 cm x 5 cm x 12.7 cm
- 390 g
- Product Type
- Enclosure Colour
- Beige
- Sensor Resolution
- 3.7 Megapixel
- Optical Sensor Type
- CMOS
- Effective Sensor Resolution
- 3,686,400 pixels
- Optical Sensor Size
- 1/5"
- Frame Rate (Max Resolution)
- 15 fps
- ISO (Max)
- 1600
- Digital Zoom
- 4x
- Print Standard
- Exif Print support
- Auto Focus
- TTL contrast detection
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- 800 x 800
- Interface
- USB 2.0
Exposure & White Balance
- Light Sensitivity
- ISO auto (100-1600)
- Exposure Metering
- Multi-segment
- Exposure Metering Zones
- 256
- Exposure Modes
- Programme, bulb, automatic
- Shooting Programs
- Split shot, double exposure, frame grab, timeshift collage, collage
- Special Effects
- Sepia, monochrome, partial colour, Vignetting, Nostalgic, Cornelius, Luna, Immerse, Amber, Marmalade, Martini, Roppongi, Highline, Skin Brightening
- White Balance
- Automatic
- Max Shutter Speed
- 1/7500 sec
- Min Shutter Speed
- 10 sec
Lens System
- F/2.4
- Focal Length Equivalent to 35mm Camera
- 33.4mm
- Focus Adjustment
- Automatic
- 10 cm
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode
- Effective Flash Range
- 0.5 m - 2 m
Additional Features
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- Auto power save, date/time stamp, cropping an image, brightness control, USB charging, integrated selfie mirror, vignetting control
Display
- 2.7" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Built-in
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B)
- Included Accessories
- Wrist strap, USB charging cable
- Battery Type
- Lithium Ion - integrated
- Details
- Battery Life Details
- Photo printing - 100 shots
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- 11.9 cm
- 5 cm
- 12.7 cm
- 390 g
- Weight Details
- Camera only: 390 g , Camera with memory card and film pack: 440 g
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
