Fujifilm Fuji Instax Square SQ20 Hybrid Instant Camera - Beige
Quicklinx: GP8PWS00 Mfr#: 16603218
Colours:
The instax SQUARE SQ20 allows you to creatively showcase the beauty of moving subjects. Whether you're capturing that exciting moment or a thrilling adventure the instax SQ20 allows you to enjoy photography and instant prints like never before.
  • Frame grab
    Shoot a video up to 15 seconds long, use the dial on the back of the camera to select the frame that captures the best moment and print your photo. Capturing a moving subject has never been so easy.
  • Timeshift collage
    Four images can be taken with a time difference at one time. Press the shutter button to shoot when four images appear on the monitor. The time difference between frames can be adjusted within 0.2 to 2.0 seconds.
  • Selfie mirror
    A mirror is included next to the lens to ensure the perfect selfie every time.
  • Digital zoom
    The SQ20 includes a digital zoom function. The digital zoom allows you to zoom up to 4x to adjust your view.
Fujifilm Instax SQUARE SQ20 - digital camera
Digital camera - compact with instant photo printer
Memory Card Slot
microSD card
Sensor Resolution
3.7 Megapixel
Max Video Resolution
800 x 800
Lens System
F/2.4
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Digital Zoom
4x
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
Li-ion rechargeable battery (included)
USB 2.0
Beige
11.9 cm x 5 cm x 12.7 cm
390 g
Enclosure Colour
Beige
Sensor Resolution
3.7 Megapixel
Optical Sensor Type
CMOS
Effective Sensor Resolution
3,686,400 pixels
Optical Sensor Size
1/5"
Frame Rate (Max Resolution)
15 fps
ISO (Max)
1600
Digital Zoom
4x
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
Digital Video Format
H.264
Image Recording Format
JPEG
800 x 800
USB 2.0
Exposure & White Balance
Light Sensitivity
ISO auto (100-1600)
Exposure Metering
Multi-segment
Exposure Metering Zones
256
Exposure Modes
Programme, bulb, automatic
Shooting Programs
Split shot, double exposure, frame grab, timeshift collage, collage
Special Effects
Sepia, monochrome, partial colour, Vignetting, Nostalgic, Cornelius, Luna, Immerse, Amber, Marmalade, Martini, Roppongi, Highline, Skin Brightening
White Balance
Automatic
Max Shutter Speed
1/7500 sec
Min Shutter Speed
10 sec
Lens System
F/2.4
Focal Length Equivalent to 35mm Camera
33.4mm
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode
Effective Flash Range
0.5 m - 2 m
Additional Features
Self-Timer Delay
10 sec, 2sec
Additional Features
Auto power save, date/time stamp, cropping an image, brightness control, USB charging, integrated selfie mirror, vignetting control
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Connector Type
USB 2.0 (5 pin Micro-USB Type B)
Wrist strap, USB charging cable
Battery Type
Lithium Ion - integrated
Details
Battery Life Details
Photo printing - 100 shots
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Included
No
11.9 cm
5 cm
12.7 cm
390 g
Weight Details
Camera only: 390 g , Camera with memory card and film pack: 440 g
5 °C
20 - 80% (non-condensing)
