With FUJIFILM digital cameras, you can make instax prints by sending the images directly from your camera to "instax SHARE".
- Wireless printing via Wi-Fi
 - High-speed printing – nought to print-ready in just 13 seconds
 - Iconic SQUARE format instax prints – 62mm x 62mm
 - Multiple filter options via the free instax SHARE app
In The Box
- instax SHARE SP-3 Printer - White, USB Cable, NP-50 Rechargeable Li-ion Battery, Instruction Manual
You can now share the images that you can only achieve with digital cameras, such as children and pet images captured at fast shutter speed, or food and flower images with blurred backgrounds, by making them into instax prints on the spot.
Making dream shots a reality
Taking the best pictures from your smartphone (or social media account), the instax SHARE SP-3 stylishly presents them in a sophisticated colour square format instax print. All with a single click of a button.
Print here, here or even here
Forget the cables. We did. Simply choose your favourite shots on your phone or compatible FUJIFILM X Series camera and transfer via Wi-Fi from the instax SHARE app to the instax SHARE SP-3. No need to plug in. No need to detangle. 100% seamless.
Moments that'll never fade
Gradations? Not a problem. Facial expressions? Crystal clear. Using the professional high-quality film technology of Fujifilm and a high printing resolution of 800 x 800 pixels and 318 dpi, your pictures will be rich, detailed and stunningly colourful.
Naught to print-ready in 13 seconds
The instax SHARE SP-3 is fast. Maybe not as fast as a rocket, but with the instax laser exposure system the SHARE SP-3 can achieve a printing time of just 13 seconds. Astounding. Plus, printing noise is incredibly low, unlike a rocket.
Make it your own
Open up the instax SHARE app and get carried away with endless filter options. Make colours punchier, enhance the mood in your shot or even take colour away. All before connecting to the SHARE SP-3 and hitting print.
Enter a world of creativity
Taken the shot? The fun doesn't have to stop there. Open up the instax SHARE app and let the collage, dicing or even messaging features commence. The show-stopping designs will give you plenty of ways to make the text bespoke to you.
Creative prints from smartphone
Select your best shots from your smartphone and get instax prints by just transferring the shots from the app to SP-3 via Wi-Fi connection. -
High-speed printing in 13 seconds
An advanced laser exposure system achieves a faster printing time of 13 seconds from print data transfer to print output. At the same time, printing noise is lower which makes your printing experience much more enjoyable. -
High definition & high image quality ideal for photos
High resolution with print pixels of 800 x 800 dots and of 318 dpi clearly shows detailed gradations and the face expressions of a full-length portrait, characters, materials, etc. -
Real Time Template
When you select Real Time Template and take a photo, the date, place, weather, temperature, and humidity are indicated in the frame. Since you cannot make a copy with this template, the photo will be the one and only in the world. -
Limited template
Each print is numbered so it looks like a limited item. A memory shared with people you cherish will be even more precious. -
Fujifilm Intelligence Filter
The Fujifilm Intelligence Filter uses an optimum processing technology, Image Intelligence, which is based on Fujifilm's 80 years of experience and ever-advancing know-how. The technology gives real results - for example, to brighten up a photo that turned out too dark.
 - Fujifilm instax SHARE SP-3 SQ - printer - colour - LED
- Printer Type
 - Compact photo printer - LED - colour
- Form Factor
 - Portable
 - 312 g
- Max Media Size
 - 72 x 86 mm
- Max Media Size (Custom)
 - 72 mm x 86 mm
- Max Resolution (Colour)
 - 318 dpi
- Interface
 - Wi-Fi(n)
- Total Media Capacity
 - 10 photos
- Networking
 - Print server
- Printer Features
 - Split, collage, real time template, limited template, standard template, custom filter, colour filter, intelligence filter
- System Requirements
 - Android 4.0.3 or later, Apple iOS 8.0 or higher
- Enclosure Colour
 - White
 - 1-year warranty
 - 11.6 cm x 4.44 cm x 13.05 cm
- Printer Type
- Enclosure Colour
 - White
Printer
- Connectivity Technology
 - Wireless
- Interface
 - Wi-Fi(n)
 - 318 dpi
- Printer Features
Media Handling
- Max Media Size
 - 72 x 86 mm
 - 72 mm x 86 mm
- Media Sizes
 - 62 x 62 mm
- Max Printing Width
 - 62 mm
- Max Printing Length
 - 62 mm
 - 10 photos
- Networking
 - Print server
- Included Accessories
 - Ferrite core, rechargeable lithium ion battery pack
- Cables Included
 - 1 x USB charge cable
 - JPEG graphics support
- Power Device
 - Power adapter
 - 3 Watt
- OS Required
 - Limited warranty - 1 year
 - 5 °C
 - 40 °C
 - 11.6 cm
 - 4.44 cm
 - 13.05 cm
 - 312 g
