Fujifilm Fuji Instax Mini Evo Hybrid Instant Camera
Quicklinx: GP7JWS00 Mfr#: 16745157
The instax mini Evo embodies a modern generation of analog, combining a classic look with more ways to create.
Show how you see the world
  • Film Dial - Use the dial to switch film effects
  • Lens Dial - Use the dial to switch lens effects
  • Print Lever - Pull the lever to print
100 Different Expressions
Use the lens and film dials in combination to express your creativity in 100 different ways. Set up and capture your unique shots using the LCD screen. The mini Evo sparks ideas to unlock endless ways to express yourself!
App connectivity for simple use
Bluetooth connectivity
Print pictures from your Smartphone.
Send pictures from your Smartphone to the camera and print them out.
  • Film dial
    Use the dial to switch film effects.
  • Lens dial
    Use the dial to switch lens effects.
  • Print lever
    Pull the lever to print.
  • 100 different expressions
  • Print pictures from your smartphone
    Send pictures from your smartphone to the camera and print them out.
  • Printed picture taken by the camera can be save to your smartphone
    Printed pictures can be saved as images with an instax frame on your smartphone. Share your favorite shot on social media!
  • Use your smartphone as a remote control
    Release the camera shutter using your smartphone as a remote control.
  • High print quality
    There are 100 different and fun ways to express yourself and get high quality instax prints.
Fujifilm Instax mini Evo - digital camera
Digital camera - compact with instant photo printer
Optical Sensor Type
CMOS
Optical Sensor Size
1/5.0"
ISO (Max)
1600
Image Recording Format
JPEG
Bluetooth
Connectivity Features
Remote control via mobile devices, wireless image printing
Exposure & White Balance
Light Sensitivity
ISO auto (100-1600)
Exposure Metering
Multi-segment
Exposure Metering Zones
256
Exposure Modes
Automatic
Special Effects
Sepia, Mirror, Vivid, yellow, blue, red, fisheye, soft focus, monochrome, normal, Retro, Vignette, Blur, Canvas, Pale, Colour shift, Light leak, Double exposure, Half-frame
White Balance
Automatic, presets
White Balance Presets
Fine, incandescent, fluorescent, shade
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1/4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
F/2.0
Focal Length Equivalent to 35mm Camera
28mm
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode
AF illuminator
Effective Flash Range
0.5 m - 1.5 m
Printer
Printing Resolution
638 x 318 dpi
Additional Features
Additional Features
RGB primary colour filter, USB charging
Display
3" LCD display
Display Format
460,000 pixels
Display Form Factor
Built-in
Connector Type
USB (power only) (5 pin Micro-USB Type B)
Battery Type
Lithium Ion - integrated
Details
Li-ion rechargeable battery (included)
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Image Storage
JPEG 2560 x 1920
12.29 cm
3.6 cm
8.7 cm
285 g
20 - 80% (non-condensing)
