This is it. The exclusively inclusive instax Link WIDE printer has landed. Creating the largest prints in the instax lineup, this wide-format 'must-have' is the smartphone printer that gets everyone in.
Real friendships deserve WIDE moments
In our opinion, the 'fullness' of every moment should be captured for all to see. That’s why we say print it WIDE. Overflowing with features that ensure nothing is lost, the Link WIDE lets you relive the buzz, again and again.
And via the app, beautifully framed WIDE prints can be enriched with colour, enhanced with QR messages and even personalised with sketches.
Supercharged simplicity
You're on! Sharing moments together couldn't be easier. Via the Link WIDE app, select the image you want to print and do your thing. Add text, resize, apply a filter, play with the contrast - the options are endless. Then connect wirelessly via Bluetooth to the Link WIDE before swiping up to print.
And pause…
Set your memories in motion free with the Link WIDE app. Scroll through your favourite videos, select the perfect moment, then print them WIDE. While you're at it, how about upping the shareability with QR hidden messages? Or a URL link to the video?
Choose your look
Choose instax Rich for all the colour or instax Natural for a classic feel - two very different colour outputs, two distinctive ways to inject vibrancy into memorable moments before printing them instantly onto WIDE film. What mode will you choose? Bright and immersive or saturated and classic?
                Simple printSelect and edit your photo from your smartphone, then print.
                QR print modeAdd richness to the moments that matter most with a QR code.
                Editable template printChange the colors and text on a variety of templates. It's easy to create a template all your own!
                Collage printPrint images with multiple photos.
                Various stickersDecorate your photos with unique stickers!
                Sketch, edit & printImport and add your sketches or text to your photo, then print!
- Fujifilm instax Link Wide - printer - colour - LED
- Printer Type
- Compact photo printer - LED - colour
- Form Factor
- Portable
- 340 g
- Max Media Size
- 86 x 108 mm
- Max Media Size (Custom)
- 86 mm x 108 mm
- Print Speed
- Up to 5 ppm - colour photo - 86 x 108 mm
- Max Resolution (Colour)
- 318 dpi
- Interface
- Bluetooth 4.2 LE
- Language Simulation
- JPEG, PNG, HEIF, DNG
- Total Media Capacity
- 10 photos
- Networking
- Print server
- Printer Features
- Brightness correction, QR print mode, editable template print, collage print
- Battery
- Lithium Ion
- Enclosure Colour
- Ash white
- 13.9 cm x 3.37 cm x 12.75 cm
- Printer Type
- Enclosure Colour
- Ash white
Printer
- Print Speed
- Up to 5 ppm - colour photo - 318 dpi - 86 x 108 mm
- Connectivity Technology
- Wireless
- Interface
- Bluetooth 4.2 LE
- 318 dpi
- Printer Features
Media Handling
- Max Media Size
- 86 x 108 mm
- 86 mm x 108 mm
- Media Sizes
- 86 x 108 mm
- Max Printing Width
- 62 mm
- Max Printing Length
- 99 mm
- 10 photos
- Networking
- Print server
- Included Accessories
- Stand, wrist strap
- Cables Included
- 1 x micro-USB charge cable - 30 cm
- Reset button, JPEG graphics support, PNG image support, HEIF image support, DNG image support
- FCC CFR47 Part 15 B, EN 62479:2010, RoHS 2011/65/EU, Directive 2014/53/EU, EN 301 489-17 V3.1.1, EN 62368-1:2014+A11:2017, EN 300 328 V2.2.2, EN 301 489-1 V2.2.3, RoHS 2015/863/EU, EN/IEC 63000:2018, EN 61000-3-2:2019, EN 61000-3-3:2013+A1:2019, IEC 61000-3-2:2019, UKCA, EN 55035:2017/A11:2020, EN 55032:2015+A11:2020 Class B
- 3 Watt
- Lithium Ion
- Run Time (Up To)
- 100 pages
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- 13.9 cm
- 3.37 cm
- 12.75 cm
- 340 g
